Speedometer recal. 2001 f250 superduty
j.osbourn80
Vehicle: f250, 7.3 turbo diesel, 2001
Post by j.osbourn80 » Wed Nov 02, 2016 11:21 pm
So I have 35x12.50r17 (318/72r17)-metric conversion.. Bf Goodrich Ko2 tires on my truck. I have worked out that at 70 mph on speedo I am doing 77 via gps and my edge insight cts. I am 10% off on my speedometer I have also done the math and figured out that there are 601 revolutions per minute at this size. Tire size information is contained within the ABS module for this year model truck and there are several sizes listed within that it can be changed to. However my size is not one of them..... does anyone know how to manually enter this in or even if it can be done?
akcooper9
Vehicle: 03 F250 7.3
Re: Speedometer recal. 2001 f250 superduty
Post by akcooper9 » Mon May 22, 2017 8:59 pm
j.osbourn80 wrote:So I have 35x12.50r17 (318/72r17)-metric conversion.. Bf Goodrich Ko2 tires on my truck. I have worked out that at 70 mph on speedo I am doing 77 via gps and my edge insight cts. I am 10% off on my speedometer I have also done the math and figured out that there are 601 revolutions per minute at this size. Tire size information is contained within the ABS module for this year model truck and there are several sizes listed within that it can be changed to. However my size is not one of them..... does anyone know how to manually enter this in or even if it can be done?
Any one have any luck on this?
akcooper9
Post by akcooper9 » Mon Sep 11, 2017 8:46 pm
BUMP
ThatOneDude
Post by ThatOneDude » Tue Sep 12, 2017 1:14 am
You may be able to change to one of the listed sizes and compare your as built data to see what changes, then apply your worked out tire rotations into that section of the as built data. I've never done this myself, so I can't be much help with anything more specific.
akcooper9
Post by akcooper9 » Sat Nov 11, 2017 4:03 pm
ThatOneDude wrote:You may be able to change to one of the listed sizes and compare your as built data to see what changes, then apply your worked out tire rotations into that section of the as built data. I've never done this myself, so I can't be much help with anything more specific.
I downloaded the AS BUILT from the truck and online. Here is a screen shot of the current state of the ABS module in my 03 7.3 PSD. Note, the tires have been adjust by the FORD tool a few years back so I wonder if that is what is causing the 'error' in the two lines that say Tire Size. Any thoughts or suggestions on what to do next? I would really like to figure this out but need some help if possible. Thanks!
fabrijack
Vehicle: 2016 F350 6.7 powerstroke
Post by fabrijack » Mon Jan 08, 2018 2:44 am
when you adjust the 2001's with ford software you change the revs/mile in the antilock brake module. 600 rev/mile was minimum the system would take. I don't know if you can access this with forscan as I don't have my older superduty to test it on.
Hope this helps,
Jack
delirious
Vehicle: Ford F150 2010 V8
Post by delirious » Thu Mar 15, 2018 5:28 pm
join this facebook group. https://www.facebook.com/groups/2775094 ... oup_header
once added, do a search within the group under speedomter or tires. once found, it will tell you what to change and there's an excel calculator in there to either change the percentage off from your baseline code or you can enter your tire data. I haven't tried it but will soon.
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
