Support for RGTM - Rear Gate/Trunk module not given?
Kingsammy
Vehicle: Galaxy, Duratorq-Turbo Diesel 2.0 L/182 kW, 2015
Post by Kingsammy » Fri Oct 21, 2016 9:48 am
I'm currently using Forscan V2.3.4 on Windows 10 and it works very good. Forscan finds e.g.the module RGTM - Rear Gate/Trunk.
But i can't find the module in the list (AS_BUILT format) when i press the programming icon. Is there a reason why the module is not shown in the list to programm? Many thanks.
Re: Support for RGTM - Rear Gate/Trunk module not given?
Post by fordsmax471 » Tue Dec 17, 2019 6:01 pm
Hi !
I discovered that too 8-)
same story here :o
Forscan finds e.g.the module RGTM - Rear Gate/Trunk but i can't find the module in the list (AS_BUILT format) :cry:
Windows 10 & ELS27 v4
Andyfocus
Post by Andyfocus » Tue Dec 17, 2019 6:53 pm
i doubt the rgtm module will need an as built as it is probably operated via the bdycm and wont need any info apart from open / close when told to do so by the bdycm or the alarm function (lock - unlock)?
Post by fordsmax471 » Tue Dec 17, 2019 7:09 pm
thanks, then fine
