Enable Cr Ctrl on Crown Vic Pol Intcptr?
Earnest
Vehicle: Ford CVPI 07
Post by Earnest » Thu Oct 20, 2016 11:41 pm
I have spent many hours the last several days trying to find out which byte I need to modify to enable cruise control on my 07 Ford Crown Vic police interceptor.
I can change the settings such as Dark car mode and it stays changed. So it seems the hardware and software are configured correctly.
I just can't find two little bits of information: which byte to change, and what to change it to in order to activate cruise control.
Does anyone have any suggestions about where I can find these two bits of information?
Thank you.
Earnest
Re: Enable Cr Ctrl on Crown Vic Pol Intcptr?
Post by Earnest » Sat Oct 22, 2016 12:40 am
This is the data I am able to change in FORscan.
(Your usage may vary.)
ABD = As Built Data
The first column is the memory location.
PCM 1
The second and third columns are the data.
FFFF FFFF
The last column can be ignored because it is the check sum for the row.
020F
Modules in FORscan UI:
PCM (Powertrain Control Module) ABD
PCM 1 FFFF FFFF 020F
PCM 2 FF0E 33FF FF50
PCM 3 FFFF FFFF FF0E
PCM 4 FFFF FFFF FF0F
PCM 5 FFFF FFFF FF10
PCM 6 FFFF FFFF FF11
PCM 7 FFFF FFFF FF12
PCM 8 FFFF FFFF FF13
PCM 9 FFFF FFFF FF14
BCE (Before Crash Event? Because Cars Evolve? Brake Control Environment?) ABD
A0-01 2000 0000 01C2
A0-02 2000 0000 01C3
A0-03 2000 0000 01C4
A0-04 2000 0000 01C5
A0-05 2000 0000 00C5
A0-06 AFAF AF00 00B3
A0-07 E000 0305 0493
A0-08 2815 C400 00A9
58-01 3030 3032 4661
58-02 4148 5037 319B
58-03 5733 3758 31A5
58-04 3434 3035 355E
LCM (Lighting Control Module) ABD
70-01 F418 0000 FF7C Dark Car Enable 1111 0100 0001 1000
70-01 F41C 0000 FF80 Dark Car Disable 1111 0100 0001 1100
FORscan parameters module - Human readable modifications
LCM .......................... Options ........... Orig
Dark Car (DC) .............. Enable/Disable .. En
DayTime Runng (DTR) .... Enable/Disable .. Dis
Turn Sig Warn (TSR) ....... Enable/Disable .. Dis
IC (Instrument Cluster) ABD
720-01-01 0A00 33
VDM (Vehicle Dynamics Module) ABD
721-01-01 0005 090D 1055
721-02-01 1316 191D 21AB
721-03-01 252B 3036 3C1E
721-04-01 434C 5464 78EC
721-05-01 D1CA BEB2 A0D9
721-06-01 8E7D 6C55 433E
721-07-01 3525 1A0C 06B6
721-08-01 0403 0201 003B
721-09-01 A600 0000 00D8
DDM (Driver Door Module) ABD
A0-08 2C15 C400 00AD #1 SU en, WW en 0010 1100 0001 0101
A0-08 2814 C400 00A8 #2 SU dis, WW dis 0010 1000 0001 0100
A0-08 2C14 C400 00AC #3 SU en, WW dis 0010 1100 0001 0100
DDM ..................... Options ................ Orig
Auto Unlock (AU) ..... Enable/Disable ...... Dis
Auto Lock (AL)......... Enable/Disable ...... Dis
Smart Unlock (SU) .... Enable/Disable ...... Dis
WigWag (WW) .......... Enable/Disable ...... En
I expect I need to change only one digit in the second or third column of the VDM or PCM to turn on cruise control.
How do I find out which one and what to change it to, please?
Thank you.
jamesbissland
Vehicle: BL Axela 2.0S
Post by jamesbissland » Sat Oct 22, 2016 8:34 pm
Hi Earnest!
You may not need to go all the way into the As Built Data to change this.. By the look of this article you can change it purely through the IDS options..
http://www.idmsvcs.com/2vmod/fordids/sc ... index.html
Maybe with a try?
James
Earnest
Post by Earnest » Sun Oct 23, 2016 3:55 am
Thank you for the response. I am not using the formal FORD IDS software. But the process you linked to was very helpful in knowing what to do once I have the correct code. I did not know the process was so involved and included a full reprogram of the PCM. (When I changed the Dark Car mode I just set the FORscan parameter to Disabled and it worked.)
I am using FORscan which was written as a FREE alternative to the IDS system. All one needs to use it is a low cost device like this one: http://www.ebay.com/itm/272329308976?_t ... EBIDX%3AIT
Unfortunately, Forscan does not have the same convenient user interface for all the data as does the Ford IDS, though some options are clearly listed. (At least for my car.) But it does give access to the data, and the ability to change it, providing one can identify which byte applies to which parameter setting.
(If I am not using the software correctly, please let me know.)
Does the IDS software give the As Built data (as shown in my post) along with the human readable data (as shown in the above post)?
If so, might someone like to identify which As Built codes apply to which human readable parameters and post what they find out on the forum, and even send the data to FORscan so they can incorporate it into their software?
Perhaps to start with, the cruise control code?
Thank you.
Earnest
Post by Earnest » Sun Nov 06, 2016 1:08 pm
I think (hope) I may have found which bit to flip to enable cruise control. But when I went to flip it, I found I could not access the PCM As Built data with the Extended FORscan program.
Is there any way to access this data with FORscan?
If not, I would be willing to attempt to modify the source code if I can get a copy of it. Does anyone know if this a possibility?
Earnest
Post by Earnest » Tue Nov 08, 2016 2:12 pm
After hearing back from FORscan, the program cannot currently modify PCM data, though there are plans to include it in the future.
cyberenz
Vehicle: crown Victoria, V8, 4.6 L,265,2008
Post by cyberenz » Tue Mar 19, 2019 10:58 pm
In the future? This was posted three years ago and we are still waiting. I think of a couple important things that forscan should be able to do easily is equipment additions, remote door modules and getting out of dark mode. They took care of a few things already but what about the other? There's probably a possibility of destroying the PCM by fooling around with it, I understand that, but if the forscan folks could just write a simple speed control yes or no, that's all we would need. Maybe I'm being too simplistic in my ideas? Anyway that's my two cents ...thanks guys here and the forscan folks for all the good work you're doing.
