FORScan not working anymore since Win10-Update
autotrans
Vehicle: HONDA VTEC 1600 2003
Re: FORScan not working anymore since Win10-Update
Post by autotrans » Wed Oct 25, 2017 7:59 am
Hi folks
As well as forscan I use a number of diagnostic programs on the same pc. Bmw Toyota Honda ect, most
seem to have problems with windows 10. My solution was to ( run boot it bare metal ) and use several partitions.
one for windows 10 the others for win 7 which is far better for diagnostics.
boomhauer1234
Vehicle: 2014 Ford Fusion 1.5
Post by boomhauer1234 » Fri Apr 13, 2018 10:11 am
Buddyl71 wrote:Hello Again,
Happy to say I now have the Latest Beta version working!! :D . The Issue was with my Internet Security Program (Trend Micro). I had to tell the Security to ignore Forscan program when it is run. For some reason it sees it as a threat and won't allow it to run.
Hope this helps some of you Guys with similar issues.
Had the same issue, thanks for posting this. :D
zajetz
Vehicle: grand c-max, diesel, 2000/163
Post by zajetz » Sun Jun 03, 2018 5:46 pm
Hi there
I have a similar problem with forscan. Last working version is 2.2.11. if i install newer version it doesn't work at all. Also if load a license key to 2.2.11 version, it kills the program. If i delete key from registry it start to work again.
Does somebody have a good suggestion to ,how i can get newer version to work.
hdzx
Vehicle: ford f250,6.0 diesel,2004
Post by hdzx » Tue Jun 05, 2018 9:27 pm
New laptop 5days old works great running Windows 10. Elm with usb cord
