Hi
I have mondeo 2008 2.0 tdci titanium and I was wondering can I activate DRL's with Forscan? If it's possible do I need full license of Forscan, or is it possible with free version? I have the 2.3.2 beta version for windows.
Ford mondeo 2008 DRL activation
Re: Ford mondeo 2008 DRL activation
I installed the extended version on my laptop.
But I can only find RCM module on the menu. No BCM.
So DRL activation is not yet possible on mk4 mondeo?
What kind of adapter do you have? Does it have am HSCAN/MSCAN switch? Your BCM could be on MSCAN.
I have modified adapter with the switch and usb connection. Reads both HSCAN and MSCAN.
Do you have a GEM module?
No as far as I know. With elmconfig you need to read the BCM and then make changes thru central configuration.
My 2010 Fusion (US version of the Mondeo) has GEM module, no BCM and no central configuration.
DRL's sorted. I had to use Elmconfig for now. I like Forscan interface more, so I will keep watching future updates.
