Functional of restore and write
DuyHuynh
Vehicle: Mazda,1.5/2016
Post by DuyHuynh » Wed Jun 15, 2016 1:28 pm
Anybody could help me explain about the diference in some of module 731-01-01 and 731-01-03 as the attachment.
Why the module 731-01-03 have some function restore and write.
Thank you.
ClockWorK
Vehicle: 2015 Taurus SHO pp
Re: Functional of restore and write
Post by ClockWorK » Wed Jun 15, 2016 6:53 pm
I didn't write the software, but I assume 731-01-01, 731-01-02, and 731-01-03 are all part of one "block". The software reads / writes an entire block at a time.
When you click write or restore, it will apply to the entire block.
Violakbrowne
Vehicle: vehicle have high capacity engine
Post by Violakbrowne » Fri Jun 17, 2016 6:23 am
Sorry i don't get you what your really needed.Will you please clarify your questions and issues.Thank you so much for the post
DuyHuynh
Post by DuyHuynh » Fri Jun 17, 2016 8:57 am
Please advice me.
Thank you very much
3GUCG
Vehicle: mondeo 2.0 2001
Post by 3GUCG » Fri Jun 17, 2016 3:58 pm
In first hand take a look here http://forscan.org/forum/viewtopic.php?f=5&t=2012
In teory is very simple.
First numbers ex. 720 is the module address 01 01 is the memory address
The rest is module options coding except the last 2 numbers in every line of as-built. Those are the verifying checksum for that line of numbers.
Well the coding numbers, if you transform those numbers in binary form, results something like this " 0011 1100 1111 0000" etc.
Every number is a switch, 0 "off" - 1 "on" for an option in that module.
If you have a numerous sets of "as-built" data and the configuration of those cars you can discover what switch does what.
