EATC climate control active test - problem
3GUCG
Vehicle: mondeo 2.0 2001
Post by 3GUCG » Wed Jun 01, 2016 5:57 pm
the car in question is mondeo mkIII 2001
In older versions of forscan (2.2x) in the meniu "test" was an option -EATC climate control active test-
All was functioning correctly. In newer versions (2.3x) this option is absent.
I know about control pids and how to work with them but those options are not available there.
This menu could be put back in place?
tanks
Re: EATC climate control active test - problem
Post by FORScan » Wed Jun 08, 2016 6:25 am
Are you sure this test worked correctly with Mondeo Mk3 before restyling? It is not compatible. Originally the test was created for Focus, Fiesta and few other models.
Anyway, we have added EATC control PIDs for Mondeo Mk3, please check you PM for details.
3GUCG
Post by 3GUCG » Wed Jun 08, 2016 8:41 pm
You've been right, not all controls function as intended.
I have marked with red arrows the non functioning ones.
When i send command for the movement of "panel_DR" and "defr_DR" i hear the sound of servomotors but it's brief.
"LBLND_DR" works well and "BLOWMTR" ranges from standstill to full power between 0% to 89% from there the speed is decreasing to 3/4 the full speed.
I could not test the "RECIR_DR" because on my car is blocked.
EATC - Electronic Automatic Temperature Control
Part number: 1S7H-18C612-AD
Software version: 2000-11-01
