Fiesta Mk7 Cruise Control Addon
tupps44
Vehicle: Ford Fiesta 2012 1.6 Metal
Post by tupps44 » Fri May 06, 2016 7:33 pm
I have a 2012 Mk7 fiesta, i have fitted the extra cruise control buttons and wiring to the steering wheel, now i need some help...
Connecting Forscan i can alter the module and enable cruise control but after writing it to the ecu i am still unable to use the cruise control, any ideas guys ?
thanks !
Re: Fiesta Mk7 Cruise Control Addon
Post by FORScan » Tue May 10, 2016 4:20 am
Did you read this article?
http://www.fordownersclub.com/forums/to ... termarket/
Otherwise, any DTCs detected after adding cruise control equipment and changing central config?
satria_wr
Vehicle: 2014 Ford Ecosport 1.5L Ti-VCT 110hp
Post by satria_wr » Mon May 16, 2016 3:29 am
Did you check the wiring from IPC to clock spring? Some fiesta didnt have that installed.
2014 Ford Ecosport Titanium
PowerShift
8-A/T
and.short
Vehicle: Ford Fiesta 2015
Post by and.short » Mon May 23, 2016 1:51 pm
does anyone have experience with fitting cc on a 2015 (mk7.5) fiesta? I have ordered a steering wheel with cc buttons and I have enabled cc in central configuration with forscan. Do you believe this is enough? Does it matter that I have left the backup controller unprogrammed? (I do not have ms switch). Is it really this simple?
P.S. Any ideas what else I can play with? I have successfully enabled auto lock by speed and global opening closing.
satria_wr
Post by satria_wr » Thu Jun 02, 2016 2:08 am
and.short wrote:Hello,
Check the wiring from IPC to clockspring. If it was exist, then YES it was that simple :D
PowerShift
8-A/T
toshibman
Vehicle: Mondeo Vignale,2L, 2015
Post by toshibman » Mon Dec 25, 2017 6:30 pm
Hi, i got now probably the same problem. Im trying to solve it. But try i on highway, be careful ! Press ON btn and then SPEED + and i will probably works with CC icon in cluster.
Mine works, but not showing up set value in LCD.
