2013 Fusion DRL Disable Can't Write (interrupted?)
I was trying to disable my DRL which is just the low beam at less power. I have the extended license and I am able to get through to the point that I begin the write process but it fails at about 97% saying that it was interrupted and could not write the file. Any idea why its not working? I really want to disable these before I try to put HID's in. I am using a WiFi ELM 327 from ebay if that makes any difference.
Re: 2013 Fusion DRL Disable Can't Write (interrupted?)
Please make sure you use latest version 2.3.1 (it contains significant fixes in AB procedure comparing with 2.3.0). If the problem is still there, please send us FORScan logs for investigations. Instruction is sent to PM.
- Vehicle: Fusion, 2.0L GTDI, 2014
- Contact:
Hey if you go to BdyCM As Built. On your line 726-50-01.
Does it say 0280?
Try changing it to 017F if it does.
That turns the DRL on and off on my 2014.
Does it say 0280?
Resolved - fixed a bug with writing AB data on some models. v2.3.1 throws "Incompatible configuration" error even although the change is correct. Fixed, fix will be available in v2.3.2
