Need help with extended licence
tarikkar
Vehicle: 2015 mustang
Post by tarikkar » Wed May 04, 2016 7:28 pm
Unable to generate license key. Please make sure Hardware ID is copied correctly i keep getting this message even tho the id is correct ,
Hardware id : C2D7124A-A5D4
boozinbuzz
Vehicle: 2015 F-150 5.0
Re: Need help with extended licence
Post by boozinbuzz » Thu May 05, 2016 12:17 am
I am getting the same error.
boozinbuzz
Post by boozinbuzz » Thu May 05, 2016 3:08 am
Was just able to successfully download key. Thank you gents!
coopcity6
Vehicle: 2001 lincoln ls 3.9 auto
Post by coopcity6 » Thu May 05, 2016 4:29 am
I went through this
Make sure you have the newest version of for scan.
If you not sure dump what you have and download it. After you download it generate the ke . Don't even mess with the program other than to get your hardware id
Beyond that install it get the id and then generate license
mrmetallica
Vehicle: ford focus titanium 2009 1.6
Post by mrmetallica » Tue May 17, 2016 12:46 pm
ive downloaded licence but now forscan cant load the obd says not found please help need to sort my car out
Post by FORScan » Wed May 18, 2016 7:43 am
Connection procedure is not related to Extended license at all. So if it worked before, please try to reconnect your adapter and/or PC, it should help
mrmetallica
Post by mrmetallica » Wed May 18, 2016 7:47 pm
tarikkar wrote:Unable to generate license key. Please make sure Hardware ID is copied correctly i keep getting this message even tho the id is correct ,
how do you find out the hardware id ?
remltr
Vehicle: Ford F150 6 cylinder 2.7 EB 2016
Post by remltr » Sun May 29, 2016 8:36 pm
I am dealing with this issue right now. Forscan is up to date. All info input is correct to my knowledge, but still getting the error about incorrect info.
Please help.
T RavJT
Vehicle: 17' Ford F-250, 6.7L
Post by T RavJT » Wed Jan 18, 2017 4:31 pm
by "hardware id" are you refering to the OBDII adapter itself ID? or a computer hardware ID?
ClockWorK
Vehicle: 2015 Taurus SHO pp
Post by ClockWorK » Fri Jan 20, 2017 12:02 pm
Hardware ID is computer hardware (not OBD hardware) ID.
The ID is shown in FORScan on the About FORScan screen.
