Unable to identify the vehicle. Please contact developers.
ASC6789
Vehicle: Ford endeavour, 3.2, 2019
Post by ASC6789 »
Please help. Unable to connect the car (Ford Endeavour 2018)
Re: Unable to identify the vehicle. Please contact developers.
Post by tractmec »
ASC6789 wrote:
Thu Jun 10, 2021 2:46 pm
Not enough information to even speculate about your problem!
ASC6789
Post by ASC6789 »
I have installed the softwares using the CD received with the ELS 27 cable. When I try to establish the connection with the car 'Unable to identify the vehicle. Please contact developers.' is the error code I receive.
Mcrider
Vehicle: Ford Focus
Post by Mcrider »
Same issue here. Kuga PHEV.
When trying to connect to vehicle,
Read this link.
viewtopic.php?t=13405
Read this as well.
1) Identify where the cable was purchased - fake or not
2) Identify your computer - compatible or not
3) Identify the exact Year, Make and Model of the vehicle
4) Update your user profile to end the guessing or the exact details within the post.
lenko
Post by lenko »
ASC6789 wrote:
Fri Jun 11, 2021 6:52 am
So. Did you contact the developers?
ASC6789
Post by ASC6789 »
None of the suggested steps have worked till now
Post by tractmec »
ASC6789 wrote:
Sat Jun 12, 2021 7:11 am
1: Check with a voltmeter for Battery voltage (12V) between DLC socket Number 16 to Socket 4-5 or to Frame (Ground).
Socket 16 should be 12V+ at all times! If it is not showing 12V+ the adapter is not being powered and will never connect.
Pin 16 has it's own dedicated fuse in most vehicles so you will need to look for a fuse chart(Operators Manual may show Fuse assignment) for the Endeavour and check fuses!
2: If the ELS27 is the adapter with the big Orange Letters and Numbers(Being sold by many places online) and has the Green PCB it is not a real ELS27 But a cheap Copy that has been described here viewtopic.php?f=4&t=1904 So you may want to think about sending it back for a refund and getting a real adapter!
