2020 Ford Everest 2.3T Ecoboost
skywalkerzwj
Vehicle: 2020 Ford Everest 2.3T Ecoboost
Post by skywalkerzwj »
Dear all,
I have a 2020 Ford Everest with 2.3T Ecoboost Engine. I have purchased a OBDLinkEX, and activated the extended license for FORScan.
However, when I connect the vehicle to the laptop, FORScan keeps saying "unable to identify vehicle". Strangely, the GUI says it recognize the vehicle as "Ford Everest EcoBoost Gasoline Turbocharged Direct Injection 2.3L 2020 ( 2020 MY ), VIN: LJX*********85619".
I want to use functions such as auto-fold mirrors, disable engine start-stop, and show trailer sway control in menu. Any ideas what I should do? The log file looks like the following:
2021-06-03 21:10:40.910 [GUI Main Window] FORScan v2.3.41 beta started
2021-06-03 21:10:40.911 [GUI Main Window] Windows info: Windows 10 Enterprise, Enterprise, Client, 6.3, 2004, 19041, 19041.1.x86fre.vb_release.191206-1406
2021-06-03 21:10:40.911 [GUI Main Window] Registry ID: 6445C400-D33E
2021-06-03 21:10:40.911 [GUI Main Window] Registry Key: 2y7EA8O5G+40CkvqYX/E9IpBI9gavnA8tm56SLt0pMv1VKFF7OwNBZgOuT8Bp8lokUwtDFK4j/yQTETrAoC5ff5i9CNSwAoSLbYyqiGoSIS+wJo7FzEHGgE2Vy+KJ9Np1++arrCEx6itXgxjRKmhNXbH1s6rF06Rqsmus8ljYzyE=
2021-06-03 21:10:40.911 [GUI Main Window] Hardware Id: 6445C400-D33E
2021-06-03 21:10:40.911 [GUI Main Window] User name: Weijia Zhang
2021-06-03 21:10:40.912 [GUI Main Window] Extended License key:
2021-06-03 21:10:40.912 [GUI Main Window] Expiry date:
2021-06-03 21:10:40.912 [GUI Main Window] Checking for Extended License status...
2021-06-03 21:10:40.912 [GUI Main Window] Extended License is active
2021-06-03 21:10:40.944 [Ford Vehicle] OBDVehicle Thread started with id 3E0
2021-06-03 21:10:41.021 [Ford Vehicle] Trying FTDI #1:223010193244
2021-06-03 21:10:41.050 [Comm Adapter] Adapter Thread started with id 3F8
2021-06-03 21:10:41.360 [Comm Adapter] Error on reading data!
2021-06-03 21:10:41.361 [Comm Adapter] OBDII to RS232 interpreter not found
2021-06-03 21:10:41.361 [Ford Vehicle] FTDI #1:223010193244 works, but no ELM found with baudrate 38400
2021-06-03 21:10:41.365 [Comm Adapter] Profiling: 3 ms
2021-06-03 21:10:41.372 [Comm Adapter] Profiling: 5 ms
2021-06-03 21:10:41.373 [Comm Adapter] ELM327 detected!
2021-06-03 21:10:41.453 [Comm Adapter] Profiling: 81 ms
2021-06-03 21:10:41.457 [Comm Adapter] Profiling: 2 ms
2021-06-03 21:10:41.461 [Comm Adapter] Profiling: 5 ms
2021-06-03 21:10:41.465 [Comm Adapter] Profiling: 4 ms
2021-06-03 21:10:41.465 [Ford Vehicle] Adapter found on FTDI #1:223010193244, 115200 bps, move forward with it
2021-06-03 21:10:41.466 [Comm Adapter] I'm finishing
2021-06-03 21:10:41.477 [STN Adapter] Adapter Thread started with id 438
2021-06-03 21:10:41.517 [STN Adapter] Profiling: 40 ms
2021-06-03 21:10:41.522 [STN Adapter] Profiling: 5 ms
2021-06-03 21:10:41.528 [STN Adapter] Profiling: 6 ms
2021-06-03 21:10:41.534 [STN Adapter] Profiling: 4 ms
2021-06-03 21:10:41.538 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:41.542 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:41.546 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:41.550 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:41.554 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:41.558 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:41.562 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:41.566 [STN Adapter] Profiling: 4 ms
2021-06-03 21:10:44.522 [STN Adapter] Trying to switch baud rate
2021-06-03 21:10:44.527 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:44.600 [STN Adapter] Profiling: 72 ms
2021-06-03 21:10:44.605 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:44.606 [STN Adapter] Baud rate switched successfully!
2021-06-03 21:10:44.607 [Ford Vehicle] Checking ping delay
2021-06-03 21:10:44.613 [STN Adapter] Profiling: 6 ms
2021-06-03 21:10:44.618 [STN Adapter] Profiling: 4 ms
2021-06-03 21:10:44.624 [STN Adapter] Profiling: 5 ms
2021-06-03 21:10:44.632 [STN Adapter] Profiling: 6 ms
2021-06-03 21:10:44.641 [STN Adapter] Profiling: 6 ms
2021-06-03 21:10:44.648 [STN Adapter] Profiling: 0 ms
2021-06-03 21:10:44.652 [STN Adapter] Profiling: 4 ms
2021-06-03 21:10:44.656 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:44.660 [STN Adapter] Profiling: 4 ms
2021-06-03 21:10:44.664 [STN Adapter] Profiling: 4 ms
2021-06-03 21:10:44.667 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:44.671 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:44.675 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:44.679 [STN Adapter] Profiling: 4 ms
2021-06-03 21:10:44.695 [STN Adapter] Profiling: 15 ms
2021-06-03 21:10:44.699 [STN Adapter] Profiling: 3 ms
2021-06-03 21:10:44.713 [STN Adapter] Profiling: 13 ms
2021-06-03 21:10:44.715 [Ford Vehicle] Found PCM type: 0x130
2021-06-03 21:10:44.734 [STN Adapter] Profiling: 17 ms
2021-06-03 21:10:44.754 [STN Adapter] Profiling: 18 ms
2021-06-03 21:10:44.767 [STN Adapter] Profiling: 12 ms
2021-06-03 21:10:44.786 [STN Adapter] Profiling: 18 ms
2021-06-03 21:10:44.807 [STN Adapter] Profiling: 18 ms
2021-06-03 21:10:44.863 [STN Adapter] Profiling: 55 ms
2021-06-03 21:10:44.889 [STN Adapter] Profiling: 23 ms
2021-06-03 21:10:44.933 [STN Adapter] Profiling: 41 ms
2021-06-03 21:10:44.980 [STN Adapter] Profiling: 42 ms
2021-06-03 21:10:44.997 [STN Adapter] Profiling: 15 ms
2021-06-03 21:10:45.001 [Ford Vehicle] Ford Everest EcoBoost Gasoline Turbocharged Direct Injection 2.3L 2020 ( 2020 MY ), VIN: LJX*********85619
2021-06-03 21:10:45.002 [Ford DB Finder] Profiling: START reading QL
2021-06-03 21:10:45.006 [Ford DB Finder] Profiling: QL size 195
2021-06-03 21:10:45.010 [Ford DB Finder] Profiling: QL size 28
2021-06-03 21:10:45.013 [Ford DB Finder] Profiling: STOP reading QL. loaded 4
2021-06-03 21:10:45.013 [Ford DB Finder] Profiling: START GR
2021-06-03 21:10:45.036 [Ford DB Finder] Profiling: STOP reading GR. loaded 2
2021-06-03 21:10:45.038 [Ford DB Finder] Profiling: START loading dmrs
2021-06-03 21:10:45.038 [Ford DB Finder] Profiling: STOP loading dmrs
2021-06-03 21:10:45.038 [Ford DB Finder] Profiling: START reading QL
2021-06-03 21:10:45.040 [Ford DB Finder] Profiling: QL size 195
2021-06-03 21:10:45.052 [Ford DB Finder] Profiling: QL size 28
2021-06-03 21:10:45.053 [Ford DB Finder] Profiling: STOP reading QL. loaded 72
2021-06-03 21:10:45.053 [Ford DB Finder] Profiling: START GR
2021-06-03 21:10:45.154 [Ford DB Finder] Profiling: STOP reading GR. loaded 527
Re: 2020 Ford Everest 2.3T Ecoboost
Is the Laptop a Surface Pro X with the ARM arcitecture?
If so, is this what you're attempted?
https://blogs.windows.com/windows-insid ... ild-19041/
If not, describe the Laptop in use.
skywalkerzwj
The laptop I used is a ASUS ZenBook, with an Intel i7-1165G7 CPU (2.80G), 16GB RAM, running Windows 10 Pro (Version 2004, Build 19041.985)
Make a copy of your license and store it in a folder.
Completely uninstall FORScan
Completely uninstall the drivers for the cable
Reboot the computer.
Install the cable with the correct drivers
Install FORScan and place the license in the correct folder
Start FORScan and scan the vehicle again.
Don't be too surprised if Ford protected some networks and your device may not access those protected networks.
Also, what adapter are you using?
skywalkerzwj
Unfortunately the solution doesn't work. I am using the OBDLinkEX with the latest firmware.
Could it be that this model is indeed not supported by FORScan? The 2.3T Ecoboost + 10AT Ford Everest is only available in the Chinese market since 2020.
Interesting theory and have mentioned Ford's protected networks on a few occasions.
Your model will the first known version to fail a connection.
If you're willing to experiment, find another older Ford model and prove your combination laptop and OBDLink actually works.
Make sure you have the correct drivers from the support site and the firmware is updated.
Post your images if you can.
Another test: if there are no other laptops available, is to install VMware and create a Windows 7 Professional 32bit.
That would save the expense of another machine to purchase. The version I use for W10 is VMware 15.
Also, from your end of the planet, can you find a DLC (Data Link Connection) schematic to shows the interconnection of all modules within the network structure in English.
One last mention, is there anything attached or hidden on your model that is NOT factory.
I mention this because of added GPS tracking devices for:
Insurance companies
Banking institutions
Leasing agreements
