navigation install help
Re: navigation install help
First line:
<AS_BUILT_DATA><VEHICLE><VIN>1FAFP53U12A258905</VIN><VEHICLE_DATA><DATA LABEL=""><CODE>0BE2</CODE><CODE>3AFE</CODE>
1FAFP53U12A258905 = 2002 Ford Taurus
How is that even possible - typed in the wrong VIN.
2002 Taurus.JPG (311.45 KiB) Viewed 357 times
Read the .pdf manual again and use keyboard combination Ctrl+F
Type in the word Navigation, you will find more than 40 entries.
If you have the correct SYNC that fits that model, you may need this:
https://www.onlinefordpartscatalog.com/ ... t4z10e893b
Crashdawg
Vehicle: Ford Edge 3.5 2012
Post by Crashdawg »
Ecmbuster wrote:
Tue Jun 08, 2021 12:35 am
First line:
How is what possible?
Crashdawg
Post by Crashdawg »
First line:
not sure where i got that VIN . off my insurance card i think. i better check. This is my number 2fmdk4jc2cba02603
Thank you for pointing that out
lenko
Post by lenko »
If yours is a touch screen - bring up navigation and put your finger on the circle that shows your location and pull that circle to the actual location where your vehicle currently is at. If you are at home pull the circle to exactly where you are. My MKC navigation was out about 400 yards and when I pulled it over to my residence location where the car was at, this corrected it and has been accurate ever since. That was over 4 years ago. Never had to add an antenna.
Checked your new VIN and wow - shows all modules now.
I see that you have this module:
Global Positioning Sensor Module
GPSM 701-01-01 404A
So that should be your antenna.
Crashdawg
Post by Crashdawg »
lenko wrote:
Tue Jun 08, 2021 12:43 pm
GPSM 701-01-01 404A
Yes mine has the big touch screen, The circle around my location is flashing. not sure if thats normal I work nights and just woke up (noon) LOL when i can get coffee down i will try what you said. (Fingers crossed).Thank you for the help..Crash
Correct ID.JPG (127.42 KiB) Viewed 251 times
lenko
Post by lenko »
"Yes mine has the big touch screen, The circle around my location is flashing. not sure if thats normal I work nights and just woke up (noon) LOL when i can get coffee down i will try what you said. (Fingers crossed).Thank you for the help..Crash"
Circle flashing is normal - just draws your attention to your vehicle's location even when driving as you move along.
Crashdawg
Post by Crashdawg »
Just just noticed on the left side of display where it say GPS
There is a red X over the letters. So I guess antenna issues?
Crashdawg
Post by Crashdawg »
First line:
Will this work for the GPS ? https://www.amazon.com/dp/B08TWNVBPZ/re ... MXM10NZS1N
Thanks again for your help
lenko
Post by lenko »
As a long shot, with Forscan check to see if you still have the same line as in your original Asbuilt downloaded from the Motorcraft site:
GPSM 701-01-01 404A
The 404A should be there. If it's not - make it 404A and write. Or you may have to reload the GPS module from the original Asbuilt download if the line is missing. As ecmbuster suggested it could also be an antenna problem.
Some people also have some problems with Ebay SD cards, especially Sync2 version 3.10 downloaded from Ford.
