DPF reset Ford Transit 1.5dCi 2019
kmsjaw
Vehicle: Ford Escape
Post by kmsjaw »
Looks like you have a bug in the program. while trying to perform a service action on FORD Transit Connect 2019 i have always information - ACCESS DENIED
It is possible to fix this issue ?
thanks
regards
scummy
Vehicle: Ford transit connect 1500tdci 2019 120hp
Re: DPF reset Ford Transit 1.5dCi 2019
Post by scummy »
Actually i'm going to need to perform the same , in a similar vehicle , year , model , everything .
Did you solve this ?
Cheers
kmsjaw
Post by kmsjaw »
No answer at all mate
scummy
Post by scummy »
Hi guys any answer to this ?
Ive got Windows version 2.3.40 beta version .
I've got here the same vehicle , same year and engine , almost every service procedure that i try to do it starts the process and interrupts the process after 1% completed .
"Access denied " and then " service procedure has been interrupted "
Need to reset DPF values .
Any help Would be appreciated ,
Cheers
