Not showing all modules
gtrunner
Vehicle: 2018 Ford f150 Lariat 5.0 4wd
Post by gtrunner »
I purchased the forscan pro. Auto switches internally for both modes. Apon install I only have access to like 3 or 4 modules. I Should have access to many more. What could be causing the issue?? cant get into things like my instrument cluster or turn signals. Tried a new profile no fix, tried adjusting setting from auto or switch or relay no fix. Any help appreciated. A phone number to a tech support would be nice
Re: Not showing all modules
Post by tractmec »
gtrunner wrote:
Thu Apr 29, 2021 10:13 pm
Read this topic viewtopic.php?f=4&t=17072
as to Forscans opinion of "ForscanPro"
Do not PM me unless I expressly ask you to for a consultation!! I am not an Admin nor am I a member of the FORScan Team and all questions should be asked and answered on the Open Forum so all can benefit!
gtrunner
Post by gtrunner »
Awesome thank you looks like I fell in the bucket. But I talked t a dealer close to me and his worked as it should. So what should I do I wonder ordered awhile ago through amazon but delete the profile from my truck?? start over? These unit don't "lock" to the vehicle to they if I get another 1??
Post by tractmec »
gtrunner wrote:
Fri Apr 30, 2021 3:23 am
NO! they don't lock to the vehicle except by saved profile! I would get An OBDlink EX and send this "Pro" :lol: back as defective with a refund request and write a negative review at Amazon with a link to this article on the forum, as suggested in the first post by the Forscan team!
Yes ideally: delete all profiles, once you get an adapter that works, before you connect the new one to the car or you can just answer No: when the message comes up asking if you wish to use an existing profile!
This will force a complete read of every network tree and module. You may save the session as a new profile then!
I suspect this "Forscan Pro" :roll: is using an RTS relay for switching to MSCAN and it is not actually switching! A look in the "Module" tree list tab under the Car Icon will give you an indication of this error! No MSCAN Modules in the list no switching!
MoJo88
Vehicle: Mondeo Vignale 210ps 2017
Post by MoJo88 »
+1 for OBDLink EX. Can't really go wrong with this adapter.
OBDLink MX + is in another class.
