2017 SD 6.7 How to set up manually regen dpf
d1insd@yahoo.com
Vehicle: FORD F250 6.7 Diesel 2017
Post by d1insd@yahoo.com »
Looking to add the manual regen ability to my instrument display.
Re: 2017 SD 6.7 How to set up manually regen dpf
Not possible. That would include a replacement cluster and added software from Ford.
Ctdair
Vehicle: 2019 Super Duty F350 6.7 Diesel
Post by Ctdair »
Should be possible, I’ve done it on 2019 350 Limited. Add the DPF display on the ip control
And then in pcm plain English file select the correct option. Sorry I’m a little vague don’t have my notes with me. There are You tube videos. I’ll try to respond with more info , it’s a busy week for me so could be a few days. Basically if you disable the auto regen in your settings on the instrument panel when dpf is full it will prompt you and you can initiate manual regen. It will not initiate regen if filter not full. You can go in truck settings and turn back on auto regen at anytime. This feature is used if you know truck might enter regen but all you have planned are short trips when regen wouldn’t complete.
Ctdair
Post by Ctdair »
viewtopic.php?t=5866
This should get you there.
Wrencheswild
Vehicle: 2016 Ford F150 5.0L
Post by Wrencheswild »
I did this on my 2017 f250. I had a box that was on IPC i could select and put the truck into regen while parked. I bought a new 2021 and told the dealer to disable the auto regen and add dpf gauge to ipc. They did but I do not see the manual regen (at idle) like I did before. I am going to have to find my old as built on my 2017 and see what the change is. Or as someone suggested was there something different in the hardware that allowed me to set it up now. I am now able to select a check box for auto regen, but if I have the box unchecked I have an amber icon on cluster.
Ctdair
Post by Ctdair »
Sounds like the correct function. You turn off auto regen and if dpf is full then it gives you a pop up to start manual regen. This mod doesn’t allow regen on command unless needed
