Service Procedure Has Been Interrupted
radarman19
Vehicle: 2021 Ford F-150 XLT Sport, 2004 Lincoln Town Car
Post by radarman19 »
Okay, I have a 2021 F150 XLT with the Push-To-Start. I am running 2.3.38 Beta.
I keep getting the "Service Procedure Has Been Interrupted" error every time I attempt to write anything.
I have tried it with a battery charger on the battery and off. I have tried engine off Key on and Engine on Key On.
I can do all diagnostics and clear codes. I just can't write.
I had a 2020 F150 and the set-up I'm using worked perfectly. I am even able to still use my set-up on my 04 Lincoln Town Car. Was there a huge change between the 2020 and 2021 model year where my USB/OBDII adapter will not work?
I am using this adapter. FORScan OBD2 Adapter, VINT-TT55502 ELMconfig ELM327 modified For all Windows compatible with Ford Cars F150 F250 and Light Pickup Truck Scan Tool, Code Reader MS-CAN HS-CAN Switch Image
Re: Service Procedure Has Been Interrupted
Domain controllers including infotainment and driver assist systems are connected to a gateway node.
This is to provide the main cybersecurity layer.
The FORScan team will need to change / update and apply various "hard wired connections" similar to what Chrysler is doing with their SGM.
radarman19
Ecmbuster wrote:
Mon Mar 01, 2021 12:30 am
Domain controllers including infotainment and driver assist systems are connected to a gateway node. This is to provide the main cybersecurity layer.
So, basically FORScan will not work with the 2021 F150? Rats! I really wanted to disable that annoying double honk!
platinum99
Vehicle: 2016 ford f150 platinum
Post by platinum99 »
Yes it will work to shut the double honk off.
radarman19
platinum99 wrote:
Tue Mar 02, 2021 12:13 am
Not on the 2021....
platinum99
radarman19 wrote:
Tue Mar 02, 2021 11:21 am
Not on the 2021....
Well i have a 2021 f150 and I was able to hook up forscan and disable the honk through the BCM.
radarman19
platinum99 wrote:
Wed Mar 03, 2021 2:22 pm
Not on the 2021....
What adapter are you using? Did you update the pull down menu or the codes? Something is hosed on my end and it doesn't work. Thanks for your help.
platinum99
radarman19 wrote:
Wed Mar 03, 2021 4:36 pm
Not on the 2021....
I have the OBDLink MX Bluetooth one. the only thing I updated was Forscan itself to the 2.3.38 version
Your message earlier " FORScan OBD2 Adapter, VINT-TT55502 ELMconfig ELM327"
I made my own ELM327 and using v1.4b and has worked for many years
The OBDLink MX+ is a different beast and works quite well.
These new trucks with the new networks need a "smart adapter".
So your earlier mention, you need to prove that adapter you have on another vehicle.
From about 2018 and up, Ford changed their networks to provide more security.
The earlier J2534-2 CarDAQ Plus devices even struggled and replaced it with the CarDAQ Plus 2 because of diagnosis over IP.
radarman19
Ecmbuster wrote:
Thu Mar 04, 2021 5:00 am
So the adapter I used on my 2020 F150 will not work on my 2021 F150?
