Forscan dont show PCM module config/ Mondeo MK5 2016
Zeraw
Vehicle: Mondeo MK5
Post by Zeraw » Sat Jan 25, 2020 12:33 pm
Hello, sorry but my english is not very good, i have a problem, i want to activate a crusie control to Mondeo MK5 1.5diesel 2016, when connect to vehicle using Forscan 2.3.28 i dont see PCM config, there is only PCM AS BUILT :/
Another module config is working, i add a tire pressure, digital speed, auto lock door, etc.
I try to reinstall Forscan, install older version but still don see PCM module config
lukaszszczygiel
Vehicle: Ford Mondeo MK4
Re: Forscan dont show PCM module config/ Mondeo MK5 2016
Post by lukaszszczygiel » Fri Feb 07, 2020 8:09 am
Hi, I have the same problem.
Has anybody had a similar problem? Any help?
oncetcr69
Vehicle: mondeo 2l petrol
Post by oncetcr69 » Thu Feb 20, 2020 10:19 am
I'm same but with 2.0 petrol Ecoboost
I want to try to access it as the diesel models can and from there change internal map from 150 to 180 HP
On mine the base map is 203 and there a 240hp version
From my research it's just a torque limiter map
Post by fordsmax471 » Thu Feb 20, 2020 7:15 pm
you be updating software and deleting your old profile
Windows 10 & ELS27 v4
