forscan on a different laptop
carcamerarig
Vehicle: Transit custom 2019
Post by carcamerarig » Sun Oct 20, 2019 8:12 pm
Hi there,
I setup FORScan on a small netbook but its next to useless so i put parallels onto a macbook for some other Windows software, can i just use the same hardware number or do i need to do a fresh 2 month licence on the new machine?
Vehicle: *** Ford ***
Re: forscan on a different laptop
Post by f-wolf » Sun Oct 20, 2019 8:15 pm
Each computer generates its own hardware ID number !
carcamerarig
Post by carcamerarig » Sun Oct 20, 2019 8:17 pm
Top man, cheers :)
Post by f-wolf » Sun Oct 20, 2019 8:20 pm
No problem at all ...
What is the Hardware ID and how to get it?
Hardware ID is a special code that identifies your PC with Windows OS installed. It is generated by a special algorithm on the basis of PC components' data and used to connect Extended License key to the specific PC. The Hardware ID may change if some PC components are replaced, in this case new Extended License key has to be generated.
Post by fordsmax471 » Mon Oct 21, 2019 3:41 am
software or hardware :!:
That's right
Each new Windows OS generates its own hardware ID number !
I have repeatedly installed clean windows on the same computer and the FORScan ID will always be different
FORScan v2.4.0/Els27 v4/Elitebook 840 G6/Win10 Pro ver.2004
Focus-MK4
Post by Focus-MK4 » Tue Oct 22, 2019 3:11 pm
It is a mix of:
Hardware
AND
User (privileges)
Hardware IDs under Windows account with and without admin rights will be different. So if you have 3 accounts A, B, C and A has admin rights and B and C have no admin rights, B and C should have the same Hw ID but A and B will have different IDs.
Ford Focus MK4 YouTube Channel http://youtube.de/c/My-Ford-Focus
