P0942 Trouble code in ABS unit
barathb
Vehicle: Focus 1.5 TDCI Powershift 2016
Post by barathb » Tue Sep 10, 2019 7:29 pm
Hello all,
I have this P0942 in ABS Unit: Calibration/Parameter Memory failure.
What should I do to delete this issue? ( Currently not deletable)
2016 Focus MK3.5
Thanks and regards,
Bálint
barathb
Re: P0942 Trouble code in ABS unit
Post by barathb » Sat Dec 14, 2019 6:44 pm
The problem has been solved: :D :D :D
My problem was: Ha have changed the ABS ECU, but the HCU not.(It was the original)
So I had to changed the HCU witch was programmed to my ABS ECU, and the Failure is gone, and it is working fine.
P0942 means: the HCU and the ECU not calibrated to each other. :shock:
