Cant locate PATS function
Andyfocus
Re: Cant locate PATS function
Post by Andyfocus » Wed Nov 06, 2019 6:21 pm
Reevco wrote:
Wed Nov 06, 2019 10:39 am
Andyfocus wrote:
Tue Nov 05, 2019 1:43 pm
PIN_Calculator_setupV2018.07.21
new version is also out now
PIN-Calculator v20190709 Create Date 2018-9-26
But even if I can generate a code there's no pats module in the menu to input it or run the code,
Where can I find a safe website to download the generator program from.
I'm a newbie at this and still trying to get my head around it all, so can you take baby steps and layman terms please....
Think I will have to give up and go to the local locksmith.
currently as forscan has not implemented the code input you will need ids 113 or above , the calculator isnt free and will need a one time fee to activate it .
Reevco
Vehicle: Transit 2.2 diesel 2011
Post by Reevco » Wed Nov 06, 2019 10:47 pm
hmmmmm expensive
Andyfocus
Post by Andyfocus » Thu Nov 07, 2019 2:50 am
hmmmmm expensive
not really 114 can be got free and its $38 to activate the coder
Reevco
Post by Reevco » Thu Nov 07, 2019 8:22 pm
I do have 114.01 (It came with the WCM2 ) but never used it as I was looking in to the licences and they are between £600 and £700 for a years use so are you saying it can be used without the licence? and it will do the PATs in out code?
Just need to buy a coder for $38
Like I say I'm all new to this and it's a learning curve at the moment
Tell me more about the coder I'm all ears.
You have my full attention sir.....
Reevco
Post by Reevco » Fri Nov 08, 2019 6:20 pm
Have been watching a few videos on youtube so I'm positive I have all I need now to do key.
shaynesmith2012
Vehicle: 2015 expedition
Post by shaynesmith2012 » Thu Nov 21, 2019 6:58 am
if you do figure out how to do the PaTS function on a newer model then please share.
Reevco
Post by Reevco » Fri Jan 10, 2020 12:56 am
Given up for now :cry:
Have bigger things to work on that need my time more...
jgwinner
Vehicle: Ford F-150, V6, 2015
Post by jgwinner » Mon Feb 10, 2020 3:46 am
I'm looking for the F-150 PATS function myself.
I tried FoCCCus as well, and it didn't work.
I only get PCM, APIM, DCDC, PAM, and BdyCM.
I'd be more than happy to purchase ForScan, but it seems like it's throwing more money away.
I even now have two OBDII scanners, one with the switch, one without Same results for both, no matter where I put the switch :(
So 2015 F-150's are screwed? I'm just trying to turn off MyKey, although I DO like the additional control panel input.
Would love to update the firmware too.
== John ==
jgwinner
Post by jgwinner » Mon Feb 10, 2020 3:48 am
P.S. What about http://autokeyprog.com/ ?
Vehicle: *** Ford ***
Post by f-wolf » Mon Feb 10, 2020 6:18 am
== John ==
Re, I'm just trying to turn off MyKey,
Have a read here:
viewtopic.php?f=16&t=11739
