Programowanie akumulatora
Tomek8507
Vehicle: S Max, 2.0 tdci, 180 km, 2015r.
Post by Tomek8507 » Mon Aug 12, 2019 3:44 pm
Witam, jak krok po kroku zaprogramować w forscan nowy akumulator? Ford s max 2015r 2.0 tdci
denbo
Vehicle: ford focus 16 zetec
Re: Programowanie akumulatora
Post by denbo » Mon Aug 12, 2019 5:29 pm
English my friend if you want help. Use translate
Tomek8507
Post by Tomek8507 » Tue Aug 13, 2019 6:20 am
Hello, how to change a new battery step by step in forscan? Ford s max 2015 2.0 TDCI
TimFor
Post by TimFor » Tue Aug 13, 2019 12:55 pm
I can't help, but I'd like you to write or reference why new battery needs to be reported to car?
In my older Focus 2007, I just changed it.
denbo
Post by denbo » Tue Aug 13, 2019 6:02 pm
Battery management. Read up on it.
Tomek8507
Post by Tomek8507 » Tue Aug 13, 2019 6:22 pm
I am looking for battery management and I can't find anything, maybe because I'm looking in Polish and that's why I can't find anything, can someone send a link?
From what I know, I need to reset something and enter new parameters, but I don't know where and what to do in Fortscan. As if someone wrote what to do in turn as I insert a new battery.
Now when I check the battery status it shows 3%, after connecting the rectifier overnight it reaches 70% but after 1 day it again drops to 3-5%. I still have a question, why doesn't it show that I have a low battery on the display? I don't have any low battery message.
denbo
Post by denbo » Wed Aug 14, 2019 7:38 am
I dont think the 3% is battery but is showing charge rate. Car needs to know what type and amperage of new battery so it can moniter it.
Tomek8507
Post by Tomek8507 » Wed Aug 14, 2019 8:36 am
As I enter forscan I can see what battery and what capacity, I think battery monitoring can be turned off. If it is possible? If so how can I change?
Motor Surgeons
Vehicle: Transit 2.2 2010
Post by Motor Surgeons » Wed Aug 14, 2019 11:21 am
If you replace the battery with the same capacity then there is no real need to tell the car. The car will work out current and voltage all by itself in time.
Doing with the scan tool just resets all the values NOW. Not telling the car just means it may take a few minutes while the engine runs. It does it quick.
Tomek8507
Post by Tomek8507 » Wed Aug 14, 2019 12:29 pm
From what you write, I do nothing in forscan after inserting a new battery? I wonder why it doesn't show a low charge, after the engine is off I can listen to music until the battery is completely discharged and nothing will show
