Cant write to IPC module - all others work
velocitybrew
Vehicle: Fusion 2.7L twin turbo, 325hp/380tq, 2019
Post by velocitybrew » Tue Aug 06, 2019 11:59 pm
This seems to be a common occurence but i wanted to start a new thread per the rules.
19 Fusion Sport - I've tried from 2.3.10 to the latest. (Excpe the August release, that installs but errors when I try to start it, then deletes the forscan.exe...) Same thing everytime. If I try to write to IPC, using a "write all" it errors out at 40%, a "single write" it errors out at 100%, both with "Service procedure has been interrupted" . Tried a USB adapter and odb2mx bluetooth adapter.
I can and have written successfully to just about every other module but I haven't been able to successfully write to IPC once.
twisterrescue
Vehicle: 2003escapeltd
Re: Cant write to IPC module - all others work
Post by twisterrescue » Wed Aug 07, 2019 1:30 am
I will grab a new 2019 fusion tomorrow .and try a mod and update asap
Post by FORScan » Wed Aug 07, 2019 4:17 am
If you use latest official FORScan release (2.3.24 at this moment) and it doesn't work, please send debug information to the support team as described here: https://forscan.org/contactus.html#debug_info. We will investigate and fix ASAP.
velocitybrew
Post by velocitybrew » Wed Aug 07, 2019 11:25 am
I can try to download and run it again but the latest update installed normally. But when I run forscan it deletes forscan.exe out of the directory and if i try to reinstall it i get an access denied error. This was on my windows 10 surface. I'll try it on my PC as well
Edit : Tested on my windows 10 PC, of course FOrscan runs >< I'll try again on my surface so I can take it to the car
Edit x2: I just realized it's "probably" antivirus killing the exe. I'll report back ! :D
velocitybrew
Post by velocitybrew » Wed Aug 07, 2019 11:35 pm
It worked! You guys are the best FORScan. :)
