2016 2.0 diesel Mondeo Mk5 P244D - Exhaust Temp Too High ....
Posted: Thu Jul 18, 2019 7:51 pm
by Davetorrance
Wonder if someone can help I have the fault code P244D - Exhaust Temp Too High For Particulate Filter Regeneration Bank 1 on my 2016 mondeo Mk5 Bi-Turbo.
The car just cut out - no warning- and would not restart.
After appx 45 minutes I was able to start and get home in limp mode.
No other codes are showing using forscan. I had the same or similar fault on the car appx 2 years ago and the ford dealer replaced the EGT sensor under warranty to resolve the problem.....
I was trying to see if I could clear the fault code by resetting the learnt EGT sensor values and monitor the sensor outputs but cannot see a function on Forscan for the mondeo Mk5 (2.0 Bi-Turbo) to reset the values.
I note you can reset the PCM module but as I am not 100% sure what that actually resets so did not try that option :cry:
Can anyone give some advice on how to reset the exhaust gas temp sensor learnt values.
Many thanks
