2010 Ford Fusion PATS
jhayes00272
Vehicle: Ford Fusion, 2.5L 4cyl, 2010
Post by jhayes00272 » Sat Jul 13, 2019 4:44 pm
Hello, I have a 2010 Ford Fusion I've been trying to get the a/c fixed on. Had a mechanic put on a new compressor and all that stuff and that all works well but it is still not working correctly. The mechanic said I should try replacing the PCM next and that I could change it myself to save some money.
I was just wondering if I can use forscan to reprogram the keys the new PCM? Thank you.
denbo
Vehicle: ford focus 16 zetec
Re: 2010 Ford Fusion PATS
Post by denbo » Sun Jul 14, 2019 8:04 am
Yes you can if you have extended license, battery back etc
jhayes00272
Post by jhayes00272 » Sun Jul 14, 2019 11:18 am
OK thank you I do still have the 2 months of extended license so hopefully all will work out then.
