climate control and entertainment not working on touch screen
winger19
Vehicle: 2013 lincoln mx v6 305hp
Post by winger19 » Fri Jul 12, 2019 12:43 am
I was working on activating navigation on my 2013 mkx and after finally getting navigation up I lost the use of my climate controls and entertainment features on the touch screen .I then removed navigation , still not working . Tried master reset but it didn't take either.Wondering if I went back to old 3.10 software version it would do the trick , thanks in advance for any help given ...Dave
denbo
Vehicle: ford focus 16 zetec
Re: climate control and entertainment not working on touch screen
Post by denbo » Fri Jul 12, 2019 1:32 pm
I will bet that no battery support or charger used and no backup done.
omar302
Post by omar302 » Fri Jul 12, 2019 2:01 pm
Suggest you check your ABD and compare it to the stock values for your car and make sure you didn't change anything else by mistake.
winger19
Post by winger19 » Fri Jul 12, 2019 3:49 pm
Guilty as charged , denbo , checked my abd ,looks good , master reset wont work at all
omar302
Post by omar302 » Fri Jul 12, 2019 4:54 pm
Try to disconnect the car's battery for all few minutes.
denbo
Post by denbo » Fri Jul 12, 2019 6:27 pm
Download the as built from ford and start again.
winger19
Post by winger19 » Fri Jul 12, 2019 8:04 pm
I tried disconnect ing the battery , no change . I will try the as built again .Thanks for the replies guys I appreciate the help very much .
winger19
Post by winger19 » Sun Jul 14, 2019 12:24 pm
Just to follow up on my issues, I loaded the 3.10 software upgrade and all my touch screen features are working again . Now to try activating navigation once more ....thanks ..Dave
DevinWright88
Vehicle: ford 3.5 twin turbo 2014
Post by DevinWright88 » Sat Aug 17, 2019 3:41 am
Can you please tell me what you did. I have just uploaded 3.10 and my climate controls still dont work. Can you show me your as built data
winger19
Post by winger19 » Sat Aug 17, 2019 9:13 pm
I just loaded the 3.10 software upgrade . My as built data is 8003-4000-029F , 2013 Lincoln mkx , sorry I can't be of more help
