"NO ELM FOUND" For 2014 Ford Fusion
dsarkis
Vehicle: Fusion SE, 4 Cylinder turbo, 2014
Post by dsarkis » Tue Jun 25, 2019 6:30 pm
I am trying to install the navigation software to my 2014 Ford Fusion SE turbo but I keep running into many issues. One big one is that FORScan won't connect to my car. I bought an ohp ELMconfig switch from amazon. I followed many forums that mentioned updating drivers. I downloaded nearly 20 different drivers and programs to get this working and it still won't. I'm super tired of this! I run windows 10. Please help
gg1234635
Re: "NO ELM FOUND" For 2014 Ford Fusion
Post by gg1234635 » Tue Jun 25, 2019 9:56 pm
does your ELM support both HS-Can and MS-Can, it will normally have a switch on it but there are some adapters that will do it automatically?
Have your tired it in a different USB port on the computer/laptop?
lenko
Vehicle: 2015 Lincoln MKC, 2.0 Ecoboost
Post by lenko » Wed Jun 26, 2019 1:59 am
On Forscan click on the second symbol from the bottom and there should be a connections settings. Make sure you bring up the elm you are using as the one to connect to. Have a look at all the other settings and set them to match what you are using.
JoaoPagliari
Vehicle: Ford Fusion 2.0 Ecoboost AWD 2013
Post by JoaoPagliari » Mon Jul 01, 2019 10:44 pm
I have the same issue when I try to connect in “real mode”.
When I finally get the connection after several time, the software recognize as the wrong car model.
I have a 2013 Fusion Ecoboost Titanium 2.0L Turbo and the software recognize as like a Focus 2002 1.8L
My device has the MS/HS switch.
I dont know what to do.
Please, apologize for my english!
