2001 Ford F-250 Crew Cab 4x4 Powerstroke 7.3L - Won't Start after PCM reset all adaptations was stuck to 6% - HELP
bkingsle8
Vehicle: 2001 Ford F250 7.3L
Post by bkingsle8 » Mon Jun 24, 2019 3:22 pm
HELLO!! Please help - I was using ForScan to change the tire revolutions for a larger tire under the ABS module and hit the PCM relearn/reset all parameters and it was stuck on 6% and unable to finish - then I disconnected after cycling key to ON/OFF and am now unable to start the truck!!!
