Ford Kuga 2015 2.0tdci non starting
Looked at this car this morning for a friend of a friend Some one else had a go and changed the high pressure pump . Car has 100000 miles and new battery fitted . It try's to start then exceeding cranking time sign came up this morning In the video i don't see any FRP b value . Any ideas https://www.youtube.com/watch?v=lNCz_f8oylI
Re: Ford Kuga 2015 2.0tdci non starting
A great idea is to post the entire scan and all the faults that were recorded.
Help us all understand ....... an new pump? A pump from the breakers? Does the pump match the original model?
I cant tell you why the pump was changed as some one else was looking at it . I was told the pump cost £180 so its not new or a recon at that price . The code that comes up is P0251
So you're not a FORScan user and posted NO images and looking for free help, correct?
https://www.techtips.ie/eXponentia/an-u ... ilure.html
Wrong i am a forscan user coming up for renewal in March . https://ibb.co/WHccq0z
also posted a link to you tube of the car turning over with the fuel pressures
2015 Ford Kuga 2.0L
P0251: Injector pump fuel metering control
Did you test and look at the fuel filter and fuel quality?
Has the air been bled away from the filter and pump?
Was the metering control measured with a voltmeter?
See if these links work
https://www.troublecodes.net/pcodes/p0251/
https://www.youtube.com/watch?v=5t273-oBjXA
https://www.youtube.com/watch?v=gEls-axWcu8
https://www.youtube.com/watch?v=R3L3IIshv04
https://www.youtube.com/watch?v=tbPrlyDFQdQ
POST screen images!
POST screen images!
