cruise control installation problem
danielnet13
Vehicle: Ford Fiesta, 1.6 TDCI, 95cv, 2010
Post by danielnet13 » Wed Sep 18, 2019 7:47 pm
Hello everyone today and I install the cruise control at my Ford Fiesta but it doesn't work and I don't know where the problem may come from. The software is activated, I am 100% sure because the green light comes on in the instrument cluster when the car is switched on. but the button does nothing when you try to activate it.
The kit that I bought to do the installation is this on aliexpress: € 89,54 7% Off | Steering Wheel Modified Frame Speed Control Switch Cruise Control Button & Cable Kit For Ford Fiesta MK7 MK8 ST Ecosport 2013
https://s.click.aliexpress.com/e/4zHYXCuu
The LED is on the button so I think the problem may be in the yellow and red cables because the cable did not come completely, you had to put the cables in the white serial connector of the car. I have welded blue in parallel with pin 3 and red and yellow in 6 and 7 as the sellers photo says.
Dessu
Vehicle: Ecosport, sigma 1.6/115hp, 2014
Re: cruise control installation problem
Post by Dessu » Sat Sep 21, 2019 6:47 pm
i have the same problem :(
LaForge
Vehicle: Ford Focus 2011 - Frostwhite LaForge Edition
Post by LaForge » Tue Oct 29, 2019 1:27 pm
Hi there,
what have you activated in Forscan?
You need to activate Cruise control in BCM and maybe in IPC
Then you need to activate ASL (if available)
Then reset Module ABS with forced module reset
Relearn vehicle Data in ABS section of Forscan Programming
check and delete DTC error Codes
Drive at least 30kmh to activate cruise control
I hope it helped
Best regards
Karsten
riding da White Beast :lol:
ECU Programming Service on Ford Vehicles after 2006
LaForge
Post by LaForge » Tue Oct 29, 2019 2:11 pm
Addition:
I have read you have to change values in 4(!) Modules to get Cruise control work.
(IPC, BCM, SCCM und PCM)
You need to activate Cruise control AND Speed limiter into this 4 Modules.
Then it will work.
Also you need the 8Pin Cable to get it work.
Best regards
Karsten
asianbloke
Vehicle: Galaxy s-max zetec 1.6 tdci 2012
Post by asianbloke » Sat Nov 09, 2019 2:11 am
Addition:
Then it will work.
Best regards
Karsten
[8 pin cable meaning???
Is there any additional electrical connections need to be done?]
LaForge
Post by LaForge » Sat Nov 16, 2019 8:09 pm
As I read you need a changed wiring set to get the additional switches work.
I don’t know deeper details but I guess dr google will help.
If you need further information, please let me know.
I’ll check my sources again to get more detailed information.
Best regards
Karsten
Paulscarbs
Vehicle: Transit 2.4 RWD
Post by Paulscarbs » Sun Mar 08, 2020 8:24 pm
Will the Forscan software work in configuring cruise and steering angle sensor on a Mk7 Transit?
Paulscarbs
Post by Paulscarbs » Sat Mar 28, 2020 7:25 am
I can confirm that the extended version of ForScan can configure cruise control.
