[SOLVED] Mondeo MK4 - loading SBL failed - why?
tecto
Vehicle: Mondeo MK4
Post by tecto » Sat Oct 05, 2019 8:42 pm
Hello to everyone - I'm new to the forum.
Today I've tried to connect my Mondeo MK4 (2014) with Forscan to enter configuration and just see what I can change there.
However I've encountered a problem, which I don't know how to solve.
I tried to enter Central Configuration (Main) but something went wrong. I tried it several times but still no success.
At first try Forscan downloaded additional files. It didn't work correctly so then I also downloaded that most popular SBL files, which are here:
viewtopic.php?f=16&t=1932
Still no success.
Please see the attached screenshots.
I still have an error Operation failed, retrying... Loading SBL failed.
I have a connection with the vehicle. I can read the DTC, clear it, read the parameters etc.
But I still cannot enter central configuration...
What I'm doing wrong?
tecto
Vehicle: Mondeo MK4
Re: Mondeo MK4 - loading SBL failed - why?
Post by tecto » Sun Oct 06, 2019 3:26 pm
Can someone help me please?
Don Ridley
Vehicle: 2016 Transit Connect
Post by Don Ridley » Tue Oct 08, 2019 7:06 pm
I think SBL loading requires a connection to the internet.
tecto
Vehicle: Mondeo MK4
Post by tecto » Wed Oct 09, 2019 8:20 am
I have an internet connection.
I recall also that during first run Forscan downloaded some additional files.
Still without success :(
Post by fordsmax471 » Wed Oct 09, 2019 12:39 pm
I'm testing today on the same car
feedback later
the test was successful ;)
check if you have any files in the CalibrationFiles folder
C:\Users\User\Documents\CalibrationFiles
if FORScan asks for a different file, download the correct file here:
https://www.fordtechservice.dealerconne ... roduct=IDS
FORScan v2.4.0/Els27 v4/Elitebook 840 G6/Win10 Pro
Post by fordsmax471 » Wed Oct 09, 2019 4:22 pm
up
tecto
Vehicle: Mondeo MK4
Post by tecto » Thu Oct 10, 2019 7:10 am
I have all the calibration files, which you showed above and also additional files from this link: http://forscan.org/download/CalibrationFiles.zip
Unfortunately it still doesn't work.
When I'm confirming to start the procedure Forscan doesn't ask for any additional files - it just shows me these errors, which I showed on first post.
I have a dedicated Ford USB interface based on STN1170 chip.
As I wrote before I have a connection with the vehicle. I can read the DTC, clear it, read the parameters etc.
Any ideas?
Post by fordsmax471 » Thu Oct 10, 2019 8:32 am
try it, delete car modules and setting-connection , set all option to "AUTO"
start with a new load
tecto
Vehicle: Mondeo MK4
Post by tecto » Fri Oct 11, 2019 6:34 am
I tried everything, which you proposed including fresh Forscan install.
I think I will try on another laptop and see the result.
One more thing - one of the users at Mondeo Forum informed me that the incorrect firmware version in my ST1170 chip might causing problems.
He even told me that maybe I should downgrade the version to the older one.
He recommented me this site:
https://www.scantool.net/downloads/updates/stn1170/
I have the latest version 4.2.4 with release date of January 30, 2017. The previous version is 3.3.1 with release date of September 25, 2012.
Since my Mondeo is 2014 I don't think it's reasonable to downgrade the version. What do you think about it?
tecto
Vehicle: Mondeo MK4
Post by tecto » Fri Oct 11, 2019 1:22 pm
Ok I solved it.
I downgraded the ST1170 firmware to 3.3.1 as mentioned above and it works correctly now.
