DDM and PDM missing on 2016 Explorer XLT
nimko
Vehicle: 2016 Ford Explorer XLT
Post by nimko » Sat Jan 12, 2019 12:55 am
Hello everyone,
I wanted to enable the Global Open/Close of my windows on my 2016 Explorer XLT. I dont see the DDM and PDM modules showing up. I have changed 3 adapters until now, 2 USB and one Wi-Fi blaming them being fake or bad copy but it seems that I am not lucky. Can somebody that has experienced this problem and has a solution help me go to the right direction ?
Thank you !
crazy4dss
Vehicle: 2016 Explorer Limited
Re: DDM and PDM missing on 2016 Explorer XLT
Post by crazy4dss » Wed Mar 13, 2019 2:19 pm
were you able to figure this out? Im having the same issues on a 2016 Limited.
crazy4dss
Post by crazy4dss » Sun Mar 17, 2019 3:20 pm
I was able to solve this myself. I was using a wifi nodule with HS/MS switch. Although it said it was compatible with FORScan it was not getting connection or making handshakes with all the modules. So i purchased a new unit this time a USB version with HS/MS switch. this is the model i got VINT-TT55502 ELM327 USB from AMAZON. Installed the drivers then all of my modules showed up.
VINT-TT55502 ELM327 USB modified For all Windows Forscan ELMconfig Focccus HS-CAN / MS-CAN compatible with Ford and Mazda
by vintscan
https://www.amazon.com/dp/B01N18TOFB/re ... JCbYE3BMSJ
nimko
Post by nimko » Sun Mar 17, 2019 10:23 pm
Would you share the drivers with me ?
steeltown98
Vehicle: 2018 Explorer XLT 4WD 3.5 V6
Post by steeltown98 » Tue Mar 19, 2019 9:30 pm
Did the two modules show up? I have an 18 XLT and cannot get them to show up which leads me to believe it does not have them?
crazy4dss
Post by crazy4dss » Tue Mar 19, 2019 11:13 pm
Windows was able to locate them itself. If it’s comes up as windows could not find the drivers. Just select option to have windows locate them automatically. If you have an issue I can help you. If you still need the drivers, here is a helpful site
http://www.totalcardiagnostics.com/supp ... 2-software
crazy4dss
Post by crazy4dss » Tue Mar 19, 2019 11:20 pm
As far as the modules all the ones I was missing appeared. So the usb device fixed the missing modules issue. I guess the Wifi handshake was too buggy for it to scan properly. Was able to do all of the mods I wanted. I disable the car running and remote not in the car honk. I also did the gear shift will not engage if the fob is not in the vehicle. I did the windows open/close feature. I disable the auto shut off timer with remote start. And I also did the reverse mirror angled for the passenger side. All I could not do prior to getting the new Port reader.
