Can't connect to elm327 bluetooth adapter
bhbrt
Vehicle: 2017 Fusion Sport 2.7TT V6 AWD
Post by bhbrt » Fri May 03, 2019 1:21 pm
Hey guys,
I purchased an obdlink lx before I did some research and after connecting it to forscan I realized it doesn't read the MS can or whatever.
So I recently purchased an elm327 adapter with the switch but I can't get it to connect to forscan. It connects to the computer fine and it connects to my phone and works with torque Pro.
Any direction on what I can do to get it connected?
Thanks,
Bobby
fordnick
Vehicle: Ford BA Fairmont 2003
Re: Can't connect to elm327 bluetooth adapter
Post by fordnick » Sat May 04, 2019 8:01 am
Have to check you've disabled bluetooth on your phone. Torque is very persistent and will probably hijack your adapter connection otherwise.
Mtonymarino
Vehicle: F150, EcoBoost 2.7, 2016
Post by Mtonymarino » Sat May 04, 2019 3:25 pm
Check out this website maybe you have the wrong driver installed.
If not then you might need to use the wired OBD elm327.
