Not seeing all the modules
timg
Vehicle: Ford 2015 F150
Post by timg » Wed Feb 13, 2019 5:35 pm
I have a elmconfig adapter with hs ms switch when I connect to 2015 f150 xl I am not seeing Ipc module Has anyone had this problem
Focus-MK4
Re: Not seeing all the modules
Post by Focus-MK4 » Wed Feb 20, 2019 3:48 pm
When during the connection all other modules are visible (some on HS possition, some on MS possition) and IPC is not showing up then it could be:
a) the module on your vehicle is not supported
b) the module is not responding - a reset is necessary (plug off the battery for some time (5 min.))
c) the adapter is somehow faulty (very low chance on that when other modules can be seen - but just wanted to mention it)
Andyfocus
Post by Andyfocus » Wed Feb 20, 2019 8:54 pm
make sure in options you have specified that the elm has a switch and to ask to switch .
