Page 3 of 13
Posted: Mon Dec 07, 2015 7:19 am
by satria_wr
Any news on as built editor? ;)
Posted: Tue Dec 08, 2015 8:01 am
Function to read/modify/write module configuration in as-built format is finished, we are now trying to implement editing it as a list of paramters, that's seems to be quite complicated thing.... as soon as it is finished, we will start beta-testing (most likely, without central configuration and PCM management ).
Posted: Tue Dec 08, 2015 9:14 am
by satria_wr
FORScan wrote:Function to read/modify/write module configuration in as-built format is finished, we are now trying to implement editing it as a list of paramters, that's seems to be quite complicated thing.... as soon as it is finished, we will start beta-testing (most likely, without central configuration and PCM management ).
Have you tried the special function in IDS? When you go to special function selection in tools, type 60247 on the column. It will show several option for direct config.
I tried to use it on my Ecosport (B515) and there are 2 option which are B515 and B515_EU. The B515 option can read but cannot edit. On the B515_EU, there is an option to read, view, edit and upload. But however, cannot read my car. Might help you to give a hint on fiesta/ecosport as build mod.
Bosch KTS 530 as passthru
Posted: Tue Dec 08, 2015 1:15 pm
by TrevvyD
Hi guys, just for your info , I have been able to connect my Bosch KTS530 mux configured as a passthru to Forscan.
For members who have a KTS of any version,,, go to Bosch passthru driver section, download the appropriate file for your version of KTS, run the software install and follow instructions.
Forscan goes hunting for the driver and loads the program without problems.
In the connection section of Forscan, leave everything as AUTO, Leave the "Auto Connect" unchecked. Mine connected up faster than IDS.
Will now go on to seeing if I can get Autel MaxiSys Pro mux to connect.
Will post results at a later date.
Cheers,,,, and Goodbye from Perth WA for now.
Posted: Mon Feb 01, 2016 9:39 am
by satria_wr
Any news on As Built editing using ForScan?
Posted: Mon Feb 01, 2016 4:21 pm
It is under internal testing now.
Posted: Fri Mar 25, 2016 4:21 pm
by gammax
we can check the mongoose interface for toyota and honda. it have j2534 drivers. and is a economic interface. i will buy one to test.
if anybody have tested with no results please tell me.
Posted: Sat Mar 26, 2016 2:24 pm
by gammax
Posted: Mon Mar 28, 2016 7:10 am
As far as we can see on the page, the adapter doesn't support J1850 (used by European Fords up to 2006 and US ones up to 2009). Other protocols (except specific like UBP) should work.
Posted: Tue Apr 26, 2016 2:24 am
by alan71
I have the VCX nano and it connects and has outperformed the ELM adapter with forscan. The speed is twice as fast and the timeouts that can occur, especially with, PATS no longer occur. Thanks again forscan for your hard work in programming the protocol fit the j2534 adapters
