Post by FORScan » Tue Jun 30, 2015 11:05 am
As-built will be added in one of next releases
mikeluscher159
Post by mikeluscher159 » Thu Jul 02, 2015 9:09 am
Does anyone have the drivers for a VCM2?
The CD that came with mine busted, and I haven't been able to load the IDS software licence, or the drivers to see if I could use it as a J2534 pass-through with FORScan.
USDM 2006 Ford Taurus using a OBDLink MX
Willing to beta test
satria_wr
Vehicle: 2014 Ford Ecosport 1.5L Ti-VCT 110hp
Post by satria_wr » Sat Jul 04, 2015 4:37 am
FORScan wrote:As-built will be added in one of next releases
Looking forward for that release. Will try using VCM2.
mikeluscher159 wrote:Does anyone have the drivers for a VCM2?
Which driver? I only install the IDS and all is well connected,...
2014 Ford Ecosport Titanium
PowerShift
8-A/T
Post by FORScan » Wed Jul 08, 2015 4:39 am
Yes VCM2 has no dedicated drivers AFAIK... The only way is to install IDS. If you use VCM2 clone, we recommend to use v92 (not newer).
May be someone will create a dedicated drivers package for VCM2 some day.
satria_wr
Post by satria_wr » Thu Jul 16, 2015 11:42 pm
V92 did not have patch yet,...
PowerShift
8-A/T
Vehicle: A6 2.8L Quattro,Volvo Bertone, Tiguan TFSI
Post by Ecmbuster » Mon Jul 20, 2015 12:01 am
Confirmed today, the Actia XS worked very good with a 2006 Ford Focus.
d3vi1
Vehicle: Mazda 3,G165 2.0,2015
Post by d3vi1 » Mon Aug 10, 2015 7:56 pm
FORScan wrote:Yes VCM2 has no dedicated drivers AFAIK... The only way is to install IDS. If you use VCM2 clone, we recommend to use v92 (not newer).
http://www.boschdiagnostics.com/pro/pro ... ord-vcm-ii
I have a Ford VCM 2 and use it with my Mazda IDS v96.04 without a problem with the latest Ford software from the link above. I had to install both the Ford Software and the Mazda one (from "c:\Program Files\Mazda Motor Corporation\IDS\Runtime\install3rdparty\ETAS") . A bit of regedit to redirect all the "VCI Software (Mazda-VCM-II)" to "VCI Software (Ford-VCM-II)" and it starts working. The VCM software from Ford and Mazda is mostly identical (even the version number) it has 2 different files and 2 different registry entries.
P.S.: And it works brilliantly with Forscan. Next step would be to add Wireless VCM support to Fordscan for iOS/Android. That would rock!!! But reimplementing the J2534 API as a shared object on top of the networked VCM communication protocol might be a bit tricky.
S117MC
Vehicle: 2002 Lincoln LS 3.9L / 2006 Ford Explorer 4.6L
UBP
Post by S117MC » Tue Aug 25, 2015 3:09 am
Will a J2534 adapter allow access modules on the UBP network? Can FORScan access them?
Re: UBP
Post by FORScan » Mon Aug 31, 2015 10:55 am
S117MC wrote:Will a J2534 adapter allow access modules on the UBP network? Can FORScan access them?
Well, from all J2534 adapters we saw only Ford VCMII does support UBP... And no, UBP is not supported for J2534 yet as testing of UBP is not successful yet (we had no chance yet to get a local access to a vehicle with UBP - as it is US market specific). If anyone has J2534 with UBP support and vehicle with UBP support, we are ready to cooperate (do necessary tests and implement normal support in FORScan).
Tony Back
Vehicle: Ford Focus
Post by Tony Back » Fri Oct 09, 2015 7:24 am
IDS V94 software can be free downloaded here
http://www.motorcraftservice.com/vdirs/ ... ftware.asp
but the latest IDS goes to IDS V97
