janekj1985
Vehicle: Ford Mondeo mk3 2.0 tddi 115hp+
Post by janekj1985 » Tue Dec 06, 2016 2:05 pm
FORScan wrote:
As far as we can see on the page, the adapter doesn't support J1850 (used by European Fords up to 2006 and US ones up to 2009). Other protocols (except specific like UBP) should work.
What Do You think about VCI-Mini for Toyota& Lexus. In desrciption they wrote it support SAE J1850 PWM?
CubeX
Vehicle: Mazda 3 SP23 Auto Sedan, 2.3l 2004 (BK)
Post by CubeX » Tue Dec 06, 2016 7:32 pm
Hallo everyone! Just want to extend a big thank you to the FORScan team for all the hard work!
I have a China VCM II Clone and I can confirm it works on a Mazda 2004 model. Programmed the As Built to enable/disable seat belt reminder.
I am willing to help test programming functions, just let me know how and where I can be of assistance. I am keen to get the AS Built decoded so that I may unlock some hidden features, like the trip computer, auto lights, auto wipers. On this year model you can not enable the trip computer from the radio by simple radio key press sequence.
adservice
Vehicle: 2017 Ford F-250 6.7L
Post by adservice » Thu Dec 22, 2016 3:41 am
Hello, you guys that are running the Vcm adapter, are you able to see all the modules? I Have a 2017 F-250 not all of my modules show up. Mostly the ones I want to play with.. lol Bcm, Tpms, etc.
Thank you
Vehicle: A6 Audi 2.8L Quattro
Post by Ecmbuster » Sat Jan 14, 2017 8:59 pm
For some added information on J2534.
This time with the new updated version 2.3.6 beta:
Working perfect is the CarDaq Plus and the CarDaq Plus 2.
This time both the HS and MS networks are in view with both CarDaq tools.
The connection is very fast and the data refresh is much faster than the ELM that I still currently use.
FORScan staff - very well done and many times I still prefer this version over the Mazda IDS.
This test was on a 2006 Mazda 3 North American vehicle
Plus and Plus 2 network connection
Post by Ecmbuster » Fri Jan 20, 2017 1:06 pm
2010 Lincoln MKZ North American version
This is another success with Forscan and the CarDaq products.
Great work Forscan staff.
CarDaq Plus and CarDaq Plus 2
atlanthus
Vehicle: 2005 ford escape v6
Post by atlanthus » Tue Jan 24, 2017 8:43 pm
I have a Blue Streak (all in one) and EEpod ...they both work well with this software !!
Harrycz44
Vehicle: Ford fusion
Post by Harrycz44 » Tue Jan 31, 2017 6:35 pm
Hi all
someone tested VAS5054 with Forscan?
robert evens
Vehicle: Focus 1.8tdci 115 ps 2006
Post by robert evens » Tue Feb 07, 2017 7:57 pm
I am a new user with Forscan
I am using a Intrepid NEO VI Fire as J2534 Pass Thru,
Had a customer with a Focus 1.8 TDCI where the engine sometimes suddenly stalled
DTC readout gave me ===PCM DTC P0088-71===
Code: P0088 - Fuel Rail/System Pressure - Too High
I then used the oscilloscoop to look at the fuel pressure and I was supprised with the refresh rate of the showed parameters
The rootcause on this vehicle was the connector on the fuel pressure sensor giving a bad connection sometimes and this showed very well in the oscilliscoop while shortly tapping on the connector.
I am used on working with other professional tools but must admit that Forscan in combination with a decent Pass thru device can be a powerfull diagnostic tool
Well done Forscan team
Xag
Vehicle: Jaguar X350 4.2 2005
Post by Xag » Wed Mar 15, 2017 2:38 pm
Greetings from the Netherlands.
Just for your information / confirmation, I use a Chinese clone Mongoose PRO JLR (€40) for my Jaguar XJ and can confirm it can connect to several busses: CAN (500 kbps), SCP (J1850 PWM 41,6 kbps), ISO9141-2 K-line (OBD2) and D2B (5,6 Mbps fiber). Many of these systems were borrowed from Ford at the time.
I use it with the Jaguar SDD software and can access all busses but the software is of course limited to what can be done from such a tool. I'm curious about the SCP (J1850) line as it controls most of the convenience stuff in my car but many projects seem to focus on CAN only nowadays. I have been reading messages from the SCP bus over an ELM (with terminal in Windows) but replaying them into the bus hasn't been a succes but that could be my own inexperience with this matter.
Also been experimenting with an Arduino but I'm not sure if the best route would be let the Arduino create the PWM signal or have it control something like an ELM or J2534 and let those generate the required signals.
Xag
autotrans
Vehicle: HONDA VTEC 1600 2003
Post by autotrans » Sun Apr 02, 2017 6:37 am
I believe it only the S type jaguar up to approx 2005 that uses 1850 pwm, for engine & transmission coms address $10
as for convenience systems, do you have an address for any of these
