New OBD MX+ FORScan does not recognize that it has MS
HextallS550
Vehicle: Mustang 5.0L 2017
Post by HextallS550 » Sun Dec 23, 2018 11:16 pm
Guessing this is a bug related to the new MX+ adapter. When attempting to pair via BT it works just fine, however, it will not allow access to MS-CAN because it thinks I'm using an ELM.
miapan
Vehicle: Mazda 6 2,0 D 120PS
Re: New OBD MX+ FORScan does not recognize that it has MS
Post by miapan » Wed Jan 23, 2019 6:25 am
Hello
I also both MX+ and it wont connect to teh car
Andyfocus
Post by Andyfocus » Wed Jan 23, 2019 12:48 pm
its connecting to the mx+ not the car by the looks of the text ?
check settings and put it too ms can and hs can use same line or something like that in the settings ,
miapan
Post by miapan » Wed Jan 23, 2019 1:46 pm
I have settings set on Auto
I tried it now on VW Golf 1,6 TDI in was abel to connect it and also reed the data.
I need to change something for my Mazda or it is possible that Mazda is not suported
My car is Mazda 6 2005 (pre facelift) 2,0 Diesel 120 HP
Andyfocus
Post by Andyfocus » Mon Jan 28, 2019 4:02 pm
some times automatic can be dodgy depending on the car , best to put it on shared line .
maybe worth tring to connect at different intervals after the ignition is turned on , or cycle the ignition a few times ( usually a ford problem thought ).
if still not working then install an older version and try again if it connects then contact forscan with a error report ? .
Chris@HBH
Vehicle: 2013 Ford Mustang GT500
Post by Chris@HBH » Fri Feb 01, 2019 3:03 am
I believe this was fixed
Narly1
Vehicle: F150 STX 3.7L 2013
Post by Narly1 » Fri Feb 01, 2019 1:11 pm
January 07, 2019 - FORScan Lite v1.3.6, FORScan Demo v1.3.6 for Android are released
Vehicle database update, migration to new core (2.3.19), support for OBDLink MX+ adapter, fixes and improvements.
January 03, 2019 - FORScan Lite v1.4.5, FORScan Viewer v1.4.5 for iOS are released
Vehicle database update, migration to new core (2.3.19), support for OBDLink MX+ adapter, work in background mode in case of using Bluetooth and BLE adapters.
December 25, 2018 - FORScan for Windows version 2.3.19 beta is released
Vehicle database update, better support for models of 2018-2019 model years, support for OBDLink MX+ and many other new functions, fixes and improvements.
Make sure you are running one of the above versions of Forscan or newer for OBDLink MX+ support.
