Unable to connect ELM327 v2.1 BT to Mazda 6 2008.
Hello, guys, I own Mazda 6 GH Estate MZR-CD 140HP 2008 year. Unfortunately there's only 1 key with it. I bought a key with 4D63 chip and provided myself a 2-month copy of Forscan and ELM327 v2.1 bluetooth scanner (pictures added). I turn the ignition key ON, Forscan detects the ELM, but when reading the vehicle info, a message appears: "Unable to read the vehicle, check that the ignition key is ON and try again.". I think the scanner is OK, because other diagnostic softwares do work with it on the same car. Past week I tried the same procedure with Vgates Scan BT piece, again no result. Is there some OBD bluetooth scanner Forscan is able to work with? Thanks!
- DSC_0100.JPG (691.46 KiB) Viewed 1062 times
Re: Unable to connect ELM327 v2.1 BT to Mazda 6 2008.
buy original adapter els27 from website els27.ru
