2014 F150 STX remote start menu IPC voltage too low
eljermc
Vehicle: F150, 5.0, 2014
Post by eljermc » Sat Feb 16, 2019 3:31 am
I got the remote start enabled through the BdyCM no problem at all. I'm trying to get the menu in the instrument panel. When I try to configure the IPC I get a voltage too low error. I connected a battery charger over night and left the charger on while running FORScan and still no luck. Could it possibly be an issue with my BAFX bluetooth adapter (without the HS/MS switch) Also wondering if anyone has any advice on the values to change for the menu to show up in the dash (720-01-02). I have read to change the middle two digits to either F0, F2 or FE which is correct for a 2014 F150 STX? I also saw a couple custom ones on the spread sheet that mention the STX anyone know what is special about those?
2B-4G10
Vehicle: F150, Gas, 5.0, 395HP, 2018
Re: 2014 F150 STX remote start menu IPC voltage too low
Post by 2B-4G10 » Mon Oct 28, 2019 10:47 am
So Sorry to hear about that and wish someone with expertise would kick-in on these questions.
best of wishes
athompson0103
Vehicle: f150, 5.3l V8, 2014
Post by athompson0103 » Tue Dec 10, 2019 6:13 pm
after having my own issues with the remote start and seeing your post, i searched the forums for any assistance. after not finding any real help and just trying to go back through the system, i remembered a simple possible fix. try the hood switch inside the engine compartment. mine was not being depressed due to not having the remote start installed by the factory. I simply zip tied mine down and the remote start worked perfectly.
I hope this helps.
