Drivers for an ELM327 for Windows 7 & 10
Stormy1958
Vehicle: px1 ranger 3.2 auto 2012
Post by Stormy1958 »
Hi all, can someone point me in the right direction. I have install just about every driver set i can find but Forscan says it cant find an ELM tool. I have the connector with the switch for HS/MS switching & i am using a usb cable...any help with where i can get the correct drivers from would be appreciated.
sloryd66
Vehicle: 2012 Ford Edge Limited
Re: Drivers for an ELM327 for Windows 7 & 10
Post by sloryd66 »
Try disconnecting the cable, close Forscan, toggle the switch, restart Forscan and reconnect the cable. Some have mentioned that the switches aren't labeled properly as to HS/MS and it will not connect initially if the toggle is in the wrong position....once started, Forscan will tell you when to flip the toggle switch to the other position.
Vehicle: *** Ford ***
Post by f-wolf »
Just have a look here ...
Maybe this will help you
(If ELM327 USB isn't setup properly as per instructions below — then OBD software will not even detect the cable — let alone connect to the vehicle.)
COramprat
Vehicle: Lincoln, Gas, 3.5L 2013
Post by COramprat »
Andyfocus
Post by Andyfocus »
if you still need the drivers then , pop open the unit , look for a 16 leg chip just where near the usb cable plug into the board,
this chip enulates serial to usb , find the number on the chip ( mine is pl-2303hx ) , then either post it here and il post the drivers or a link to them or search on elm website download , drivers section for the drivers.
veedub
Vehicle: Ford F150 2.7 2018
Post by veedub »
f-wolf wrote:
Thu Oct 04, 2018 10:19 pm
I was skeptical, but finally got drivers working with an older ELM327 module on package 5! Patience is paramount.
Claudemir Batista
Vehicle: NEW FIESTA 1.5 ANO 2014 PLACA FHM1788
Post by Claudemir Batista »
Boa noite! Adquiri um scanner ELM 327 forscan e meu notebook windows 7 fiz tudo direto com forscan mais não consigo de forma alguma configurar driver no computador com o CD que veio junto, a windows não aceita.
Pode me ajudar?
Claudemir Batista
Boa noite! Adquiri um scanner ELM 327 forscan e meu notebook windows 7 fiz tudo direto com forscan mais não consigo de forma alguma configurar driver no computador com o CD que veio junto, a windows não aceita e surgiu código erro 28.
Pode me ajudar?
Post by f-wolf »
We use English here !!
Nós usamos inglês aqui
Re,
Good evening! I bought a forscan ELM 327 scanner and my windows 7 notebook did everything straight with forscan but I can not in any way configure driver on the computer with the CD that came with it, windows does not accept and error code 28 came up.
Can you help me?
Leia aqui
Have a read here:
(Se o ELM327 USB não estiver configurado corretamente, de acordo com as instruções abaixo - o software OBD nem detectará o cabo - quanto mais conectar-se ao veículo.)
Translate
Traduzir
https://www.google.com/search?rlz=1C1CH ... _4Q4dUDCAs
goodnight142
Vehicle: 2019 Ford F250 Superduty
Post by goodnight142 »
Hey Guys. I have updated all my drivers and everytime I try to connect to forscan I get the error 'unavle to connect to vehicle. please make sure the ignition key is ON and try again' the vehicle is in the accessory mode. Still will not connect. Any advice?
