bbfly-BF32302 only shows 6 modules... normal?
photonerd15
Vehicle: Ford F-150
Post by photonerd15 » Tue Jun 05, 2018 7:09 pm
I purchased the BBFly-BF32302 to program a 2016 F-150 3.5L EB Lariat and for some reason I am only able to modify 6 modules...
I know that there are plenty more modules that I should be able to change. Is the Adapter to blame since it's cheap? Should it be reading more modules?
Thanks in advance.
Vladsky
Vehicle: 2017 Ferd PHEV
Re: bbfly-BF32302 only shows 6 modules... normal?
Post by Vladsky » Tue Jun 05, 2018 7:15 pm
photonerd15 wrote:I purchased the BBFly-BF32302 to program a 2016 F-150 3.5L EB Lariat and for some reason I am only able to modify 6 modules...
Thanks in advance.
Howdy;
Did you:
- read all the tutorials?
- install the correct Driver fer this specific adapter?
- configure the connection within Forscan correctly?
All the above info is available on this site .
Lastly - a bad adapter is also a possibility. Cheap is cheap :lol:
Salut
Vlad
photonerd15
Vehicle: Ford F-150
Post by photonerd15 » Tue Jun 05, 2018 7:55 pm
I have read tutorials provided on this site and got the correct driver (may need to reinstall).
I will definitely check to see if configuration is correct as I thought I did it right but humans do make mistakes.
Vladsky
Post by Vladsky » Wed Jun 06, 2018 1:32 pm
photonerd15 wrote:I have read tutorials provided on this site and got the correct driver (may need to reinstall).
Roger that.
The best single resource I know (with the best 2015+-specific spreadsheet link): https://docs.google.com/document/d/1-8d ... xIqxY/edit
So - assuming you have a known-good adapter & driver, configured the Connection properly in FORscan (including HS/MS switch config) AND know how to use the MS/HS switch in general ...
... about the only thing left that can cause issues is the use of Profiles. I Never use it - I Always allow Forscan to 'discover' all modules every time it loads. Reason - If you've happened to have saved a Profile of a partial Discovery (like yer list of SIX), you will Always only see a partial module list IF you continue load / use that Profile.
BTW - that tutorial has images of just how extensive the module list is on our trucks; WAAAAY more than 6, lol.
BTW #2 - ALWAYS connect a battery maintainer fer yer extended Forscan sessions. An under-voltage condition - which can readily occur while in KOEO operation - during module flashes can be fatal.
Lastly - it goes without saying to Back Up ALL of yer modules' Factory As-Built data as JOB #1. Do not perform ANY config changes until this had been done and you have Saved that data in more than one separate location / device (e.g NAS, a USB key, Cloud, etc).
Salut
Vlad
x96535
Vehicle: 2018 Ford F-150 Raptor
Post by x96535 » Thu Feb 07, 2019 6:19 am
Did you ever resolve the issue? I'm having the exact same problem, and I've gone through the tutorial step by step. Thanks
