f-wolf
Post by f-wolf » Thu Mar 14, 2019 1:02 am
Have you got the right drivers installed ??
(If ELM327 USB isn't setup properly as per instructions below — then OBD software will not even detect the cable — let alone connect to the vehicle.)
http://www.totalcardiagnostics.com/supp ... 2-software
Vehicle: FORD S-Max MK2 2,0TDCi PowerShift
Post by fordsmax471 » Mon Mar 18, 2019 8:18 pm
ELS27 v4.0 / ELM327 v2.2 HS/MS CAN USB
npuBaJIT
Vehicle: Mazda CX5 2,5 GT
Post by npuBaJIT » Fri Mar 22, 2019 5:01 pm
Which adapter better to choose for Mazda CX5 2016-2018 (uses same CAN buses as ford as I understand):
1. ELS27 V4 (of course I will have to wait till WiFi/Bluetooth version will be sold)
2. ELM 327 from https://elm-327.eu/elm_usbhsms (Because they sell it now again for some time)
3. OBDLink MX+ ? Now with discount price is 75$.
Mainly I will be using it as a scanner tool, but thinking about possibility to program some modules (for example activate new features, change and progremm new instrument cluster, or program new key if with such adapters on my car it will be possible and etc.)
Thank you in advance.
dstirrup
Vehicle: Ford BF 2008, 4.0L 190kw, Auto 4spd
Post by dstirrup » Fri Jun 07, 2019 12:39 pm
Whilst BT and WiFi are so convenient, experience is that USB is reliable and they are not. Basically BT and WiFi are just replacement connections for a cable and make the communications environment more complex just to pass thru a USB interface to the host.
richpatt
Vehicle: Ford Fusion Hybrid 2011 489000 kms
Post by richpatt » Fri Aug 16, 2019 6:46 pm
Vladsky wrote:
Sun Jun 03, 2018 12:22 pm
dickiefrank wrote:I'm getting a reading on the forscan when I try to link it to the truck...says "bad clone"...my connector does not have the toggle switch...am I to conclude that I need the one WITH that toggle switch?
The proper adapter you need is already specified above.
Suggest you start reading, Dickie :lol:
Vlad
Vlad You're a total asshole. To say "Suggest you start reading, Dickie :lol:" do you really talk to people this way? let me guess, you live alone and have no friends.
denbo
Vehicle: ford focus 16 zetec
Post by denbo » Tue Aug 20, 2019 7:29 am
I agree with vlad, too many coming on here wanting to be spoon fed. Do some research before you open a new blog.
