Issue With ELM327
Barton2013
Vehicle: F-150 v6 ecoboost 2012
Issue With ELM327
Post by Barton2013 » Sat Feb 03, 2018 3:45 am
I just received my OBD-II and am having issue using the forscan program. Forscan is able to establish connection to my ELM and recognizes the adapter etc, however when it comes time to read my vehicle I keep getting the same "(ERR) [20:57:15.193] Unable to connect to vehicle. Please make sure the ignition key is ON and try again"
I have literally tried everything on these forums, even connecting to my ELM ip address but the page is never able to load when i try to do that.
Any help with this would be greatly appreciated.
Joe
caesar
Vehicle: Ford Focus RS 2.3 2017
Re: Issue With ELM327
Post by caesar » Tue Feb 27, 2018 2:23 pm
I have exactly the same problem as you. I have tried reloading drivers and Forscan, I have even tried two ELM adaptors, but cannot get connected to the car - I've even tried two different cars but always the same result - unable to connect to the vehicle.
Please can someone help?
caesar
Post by caesar » Sat Mar 03, 2018 11:48 am
Right - I sorted it myself. Having bought two supposedly different adaptors from from two different sellers on Ebay, they turned out to be identical and not as illustrated. Both are being returned as neither worked. I then bought a totally different looking adaptor and it works perfectly.
Essef
Vehicle: Focus diesel 1.8 2004
Post by Essef » Tue Mar 06, 2018 11:37 am
caesar wrote:Right - I sorted it myself. Having bought two supposedly different adaptors from from two different sellers on Ebay, they turned out to be identical and not as illustrated. Both are being returned as neither worked. I then bought a totally different looking adaptor and it works perfectly.
Well then it would be advantages to others if we knew which "working adapter you purchased" :shock:
Essef
martin123
Vehicle: transit connect 2003 1.8 tddi
Post by martin123 » Fri Mar 16, 2018 3:13 pm
i think cdm may have bricked 1 adaptor thru driver install. read about ftdi driver bricking devices online.time to buy another. but still cant understand why my mx link wont work either
