2018 Transit cant access BDYCM Central Config (main)
the-drew
Vehicle: 2017 f150 2014 transit connect 2012 transit conn
Post by the-drew » Fri Jan 26, 2018 2:07 pm
When I try to run BDYCM Central Config (main) on 2 different 2018 transit full size I get an error and the service procedure stops and vehicle resets (cluster radio dome lights all flash once). I am able to read as built but unfortunately I am not able to find any information on hex coding for these vehicles. I have a obd link mx and teh real usb elm recommended here but they both do the same thing.
twisterrescue
Vehicle: 2003escapeltd
Re: 2018 Transit cant access BDYCM Central Config (main)
Post by twisterrescue » Fri Feb 16, 2018 12:29 am
can you even connect to car mine says call developer .starts to connect then warning comes up.
