Forscan cant connect to ELM
JaredBlight
Vehicle: F150 3.5L ECOBOOST FX4
Post by JaredBlight »
I recently got my ELM327 off Amazon. I installed all the drivers that it told me to download. I get an error saying that it cant connect to the ELM. I dont really know where to go from here. Any help is appreciated.
I am using my laptop and its a USB adapter.
zvarga
Vehicle: Mondeo 2.0 TDCI
Re: Forscan cant connect to ELM
Post by zvarga »
Hello.
I can not join ELM myself
I have a 2008 Mondeo 2.0 TDCI. Forscan does not see an ELM cyst. Win7 system can see USB (com7). I have set Forscan connection com7 ... no connection. ELM-USB cable works with other software (Focom). I asked for another wire, you do not see.
Someone gives advice
Thanks.
Zvargaa
17LimitedExpy
Vehicle: 2015 Ford Explorer Limited 3.5 NA
Post by 17LimitedExpy »
I have the same setup, double-check you download the correct driver to your computer for the ELM you are using.
I received the no ELM message on my laptop when I was trying to connect to my truck...once I downloaded the correct driver to my laptop, FORSCAN worked like a charm.
2015 Ford Explorer Limited 4WD 3.5NA
2018 Ford Explorer Sport 4WD 3.5 Ecoboost
Mezyyy
Vehicle: Ford Mondeo MK4 2.0 85kw 2008
Post by Mezyyy »
17LimitedExpy wrote:I have the same setup, double-check you download the correct driver to your computer for the ELM you are using.
Hello
I have mondeo 2008 2.0 85kw not connected.
where do you download the correct driver?
martin123
Vehicle: transit connect 2003 1.8 tddi
Post by martin123 »
If it's genuine ftdi then look online at ftdi
If not genuine try the prolific driver. Worked for my non genuine elm
