Searching for WIFI.... No ELM Found
Deacon
Vehicle: f-150 5.4 Triton 2002
Post by Deacon » Thu Dec 28, 2017 7:30 pm
On my laptop. Keep getting " Searching for WIFI. No ELM Found. Please check connection and retry." Have tried bluetooth and hard wired ELM. Same response. How do I get the program to find my ELM?
Pendaws
Vehicle: Ba Falcon 4.0 ltr 2003
Re: Searching for WIFI.... No ELM Found
Post by Pendaws » Wed Jan 10, 2018 4:02 am
I had some issues with this. I found that I needed to make the connection default. I don't know if you are using Bluetooth or USB or WiFi but, whichever you use, it might be a good idea to do what I did.
FiveLeeter918
Vehicle: 2013 Ford Taurus SHO
Post by FiveLeeter918 » Mon Jan 15, 2018 4:30 pm
^^ forcing the selection helped me to establish a connection when I was running my bluetooth dongle.
- Lee
2013 Taurus SHO PP
AWD gauge, EQ presets, Nav in Motion, Double Honk Deactivated, Signal Flash increased to 5, Engine hours enabled, DRLs enabled
Icecoldak
Vehicle: 2018 F-150 Limited 3.5EB
Post by Icecoldak » Sat Jan 20, 2018 11:33 pm
Deacon wrote:On my laptop. Keep getting " Searching for WIFI. No ELM Found. Please check connection and retry." Have tried bluetooth and hard wired ELM. Same response. How do I get the program to find my ELM?
Mine is doing the same thing and I have tried everything--I have the MXBT and the BT light is blinking but it cannot find squat lol-----the computer Im using does have the dongle which is working cause I can see the laptop on my phone! What to try next ??
17LimitedExpy
Vehicle: 2015 Ford Explorer Limited 3.5 NA
Post by 17LimitedExpy » Wed Jan 24, 2018 10:12 am
I had the No ELM...message with my USB connection...until I installed the updated/correct driver for my OHP ELM327, then worked like a charm afterwards.
2015 Ford Explorer Limited 4WD 3.5NA
2018 Ford Explorer Sport 4WD 3.5 Ecoboost
BillyR
Vehicle: F150,4.6L,2010; F350, 5.4L, 2001; F450, 6.8L,2000
Post by BillyR » Mon Jan 07, 2019 2:53 am
I had the same symptoms/problem today, turns out the CH340 connector driver needed updating. Worked fine after update.
frankthefixer
Vehicle: f150 Lariat, 5.0L V8, 2018
Post by frankthefixer » Fri Aug 23, 2019 1:32 am
Update the DRIVER for the device you are using.
For my VEEPEAK OBDCheck MS Scan Tool For MS-CAN & OBD II
device the direction was as follows:
Device Driver Sometimes the driver is already included in Windows and the device can be recognized correctly. However, if the device is not recognized, you can install the driver by the following ways:
1. Auto Update: in Device Manger, find "USB to Serial" with yellow exclamatory mark, right click it and select "Update driver", then search automatically for updated driver software (make sure you have good internet connection)
2. Download the driver and install from our website: https://www.veepeak.com/producVobdcheck-ms/
Once this is done you should be good to go.
Check the info for your own scan tool.
expy2010
Vehicle: 2010 Ford Expedition Limited
Post by expy2010 » Wed Aug 28, 2019 11:04 pm
I'm having the same problem with my ODBLinkMX+ What should the settings be? If I need to update a driver, how do I do that?
Sylvester
Vehicle: Scorpio MK2
Post by Sylvester » Tue Oct 01, 2019 3:21 pm
Also, I'm having the same problem with my ODBLinkMX+ What should the settings be?
It searchs for WiFi - but I use cable Adapter.
System Win7 prof.
buckaroo
Vehicle: 2012 f-250 6.7 powerstroke
Post by buckaroo » Thu Oct 10, 2019 11:38 pm
I have the same trouble. I'm thinking it is the elm 327 I have. Tried running the driver's for it again since I have not used the program in awhile. Still no luck.
