getting fed up with ohp ELMconfig
Posted: Tue Nov 21, 2017 3:57 am
by purpony
Purchased a ohp ELMconfig unit from Amazon to use on my 2014 Flex. Was recommended by a friend that uses this same unit on his 2015 F150.
Ive been at this for 3 hours now trying to get it to connect. I have read the ohp website here
I have installed the driver recommended by ohp --> http://www.ohp.ee/en/a/elm327-ford-inst ... structions
Device drivers for ELM327 USB device:
FTDI VCP: http://www.ftdichip.com/Drivers/VCP.htm
CP210X UART Bridge: http://www.silabs.com/products/mcu/page ... ivers.aspx
also installed a toolkit I found linked on here....
all it says over and over is "no ELM found"
any other input on what I am missing before I return this thing!
Re: getting fed up with ohp ELMconfig
Posted: Thu Nov 23, 2017 10:50 am
by ks_aus_jucunda
Which Version of Windows do you use? When Microsoft rolled out the "Creator's edition" the driver for FTDI devices failed to work. Do you see a com port in the device manager? What settings did you apply in Forscan? Try to set all to auto or choose the FTDI thing directly. Choose connection speed automatically or fix to maximum (guess it is 500,000 kbit).
Secondly, if Windows 10 is your OS, install the fall edition of it. Might solve your trouble as it did on my Windows laptop.
Let us know if anything of the above was helpful
Posted: Wed Nov 29, 2017 4:10 am
by purpony
Thank you for the reply-
I am running Windows 10 Version 10.0.15063 Build 15063
How do I upgrade to the fall edition?
When I installed the FDTI driver it said install successful.
When I go to my device manager and click on USB, it is showing COM3. Rate 9600. Also says "This device is working properly."
In ForScan I have everything set to AUTO. Not sure what or if it matters what the J2534 specific MS-CAN support... I tried both shared with HS CAN and Dedicated channel.
Posted: Wed Nov 29, 2017 3:04 pm
by purpony
ks_aus_jucunda- Thank you Thank you Thank you!!!! I upgraded my windows 10 to the fall edition last night, re-installed the FDTI driver, and all works perfect now!! Plugged it in and it connected first try! :D
Posted: Sat Apr 06, 2019 9:22 am
by Raptor207
had the same problem "no elm device detected " installed all drivers ect still no-go
found vid on utube and followed exactly works great
Hook Up sequence is the key
ohp elmconfig to Vehicle then plug into usb port(has something to do with how win10 recognized it)
key on then forscan works perfectly now :D
Posted: Sun Apr 21, 2019 2:30 am
by scotty123890
How did you find out if you have the fall edition?
Posted: Thu Jun 06, 2019 12:03 pm
by jeff6146
Ok guys my USB adapter isn’t reading some modules lines that others have used to mod and it is showing lines in modules that I have no idea about because their not found anywhere else. Is there an app for the ELM327 to use like everyone else is using. And I have no idea what FTDI is at all. Do you all think it just needs an update?
Posted: Wed Mar 11, 2020 2:12 am
by RedTagViolation
Ok so I’ve been successful with this OHP ELMconfig a few times on my last 2012 xlt F-150, I just purchased a 2019 Lariat 3.5 eco boost. It says it’s connected, reads all the blocks, even says configuration successful and to turn the vehicle off then back on. It does all the flashy things like usual, says everything is enabled, yet does not work. I have repeatedly tried enabling my fog lights with my brights and just can’t seem to get it to stick yet the software is telling me it’s a successful enable. Is this the OHP’s fault? Or something of my own. Also, which direction is high and which is medium. It was so easy before. What am I doing wrong.
