Kvaser J2534 CAN-bus interface
Pietermans
Vehicle: Fiesta mk7
Post by Pietermans » Tue Nov 14, 2017 12:04 pm
I am new to this forum & to Forscan.
I own a Kvaser Leaf Light CAN-bus interface and I was wondering if this interface is supported by Forscan.
If you install the drivers of this interface you also have the possibility to install J2534 drivers. Does this mean it will work?!
Many thansk for any reply.
Regards
Pieter
Pietermans
Vehicle: Fiesta mk7
Re: Kvaser J2534 CAN-bus interface
Post by Pietermans » Thu Nov 16, 2017 7:47 pm
sorry for my first question, I did not install the program at that time.
after installing it today I noticed that you can select the Kvaser J2534 hardware, at the moment I cannot yet connect to the car as I have to make the J1962 cable.
Only question I do have is; how do you select between HS CAN & MS CAN? or can you use a 2channel Kvaser device? connect HS CAN to channel 1 and MS CAN to channel 2?
Who can help me with this question??
autotrans
Vehicle: HONDA VTEC 1600 2003
Post by autotrans » Sat Nov 18, 2017 1:39 pm
The obd connectors use pin 6 hi and pin 14 lo for HS CAN 500k
pin 3 hi and pin 11 lo for MS CAN 250k
never used the kvaser interface, but normally there is a dropdown menu
in the software to choose the data rate.
Pietermans
Vehicle: Fiesta mk7
Post by Pietermans » Fri Jan 05, 2018 12:17 pm
Today I have connected a 2channel Kvaser device on a MK7 Fiesta. Connection seems to be perfect for the HS CAN-bus, MS CAN-bus I doubt a bit. You can not clearly select the MS CAN bus in the FORSCAN software. I connected the HS-CAN to channel 1 and the MS-CAN to channel 2.
Maybe I made a mistake with the software settings of FORSCAN?? If someone knows about this or further testing needed just let me know. I have a car & Kvaser device at hand.
