EL Falcon (Australia) Connection.
jas24zzk
Vehicle: GQ Patrol, 5.0 Windsor
Post by jas24zzk » Sat Aug 12, 2017 3:06 pm
Hi guys,
I have a 1997 EL 5.0 that is a donor for a bigger project. At this point in time the car is a runner, albeit with 2 obvious faults. I've done a little bit of research, and believe i have worked out the problem.....gotta fix before I pull the car apart.
I could do the old flash me the code thing, this would get me past this hurdle, but going forward I will need to be able to scan the systems from time to time.
From what i can see, is that the EL runs SCP, which forscan can read, but it runs a non OBD2 diagnostics port.
My question, is can I simply make a breakout cable to allow me to connect my ELM327 adapater and my laptop?
Cheers
Jas
KRL-94
Vehicle: 2004 ford falcon 4L inline 6 cyl
Re: EL Falcon (Australia) Connection.
Post by KRL-94 » Sat Sep 30, 2017 11:27 am
I'm unsure if that would work. is there a cable available that you can use to connect the obd plug to your computer??
Falcs
Vehicle: Falcon, I6 SOHC, 4L, 164kw, 1998
Post by Falcs » Fri Dec 01, 2017 11:01 am
Did you end up getting this to work?
